Normal Topic the problem for tree layout (Read 1418 times)
Lee
Sep 5th, 2013 at 2:16am
hi,Stoyan,I have one question as follow
At start,I have one tree,
then I delete some link,
at last,I have two tree,four singe nodes,
I use the treeLayout,if the set the keepPosition=ture,the 2 tree may be overloop,the nodes will be well,but set the keepPosition=false, the 2 tree will be well but the nodes will be at the same position,can you tell me how to this problem
Re: the problem for tree layout
Reply #1 - Sep 5th, 2013 at 5:53pm
I can't see any overlapping nodes in that situation, with TreeLayout applied using its default property values:
Make sure Root is null when running TreeLayout if you want it to arrange all trees in the diagram. If Root is set to some node, only the tree rooted at that node will get arranged.
