Normal Topic Can I define themes and styles in javascript (Read 3640 times)
Kiran B
Sep 8th, 2013 at 6:22am
Can I define themes and styles in JavaScript. Could you please give some sample code for this?
Kiran B
Re: Can I define themes and styles in javascript
Reply #1 - Sep 9th, 2013 at 5:30am
This sets the style of a single node:
var Style = MindFusion.Diagramming.Style;
var style = new Style();
style.setBrush("Orange");
node.setStyle(style);
This sets the style of all ShapeNodes via a theme:
var Theme = MindFusion.Diagramming.Theme;
var theme = new Theme();
theme.styles["std:ShapeNode"] = style;
diagram.setTheme(theme);
You can set style properties via the setBrush, setStroke, setStrokeThickness, setTextColor, setFontName, setFontSize, setShadowColor, setNodeEffects methods of the Style class.
Kiran B
Reply #2 - Oct 2nd, 2013 at 6:13pm
If i need to set different styles for each shape node globally, is there any way?
Ie Circle shape i need one style and square shape another style.
Could you please help me?
Kiran B
Reply #3 - Oct 3rd, 2013 at 8:31am
There is no built-in support for specifying per-shape styles. However, you could replace the ShapeNode's resolveStyle function with your own version that selects styles based on current shape:
var globalStyles = [];
globalStyles["Rectangle"] = new Style();
globalStyles["Rectangle"].setBrush("yellow");
globalStyles["Ellipse"] = new Style();
globalStyles["Ellipse"].setBrush("green");
var originalResolver = ShapeNode.prototype.resolveInheritedStyle;
ShapeNode.prototype.resolveInheritedStyle = function (check, theme)
	var styleForShape = globalStyles[this.getShape().getId()];
	if (styleForShape && check.apply(styleForShape))
		return styleForShape;
	return originalResolver.apply(this, [check, theme]);
resolveInheritedStyle is called with lowest priority after checking the node's own style, the diagram's style, and current theme. If you prefer the shape styles to have higher priority, replace the resolveEffectiveStyle function instead.
« Last Edit: Oct 3rd, 2013 at 9:44am by Stoyo »
