Normal Topic Straightening Links When a Node is Moved (Read 2366 times)
Paul
Sep 9th, 2013 at 9:40pm
Is there a property that can be set on the diagram that will remove any bends in a link when the user moves a node?
Re: Straightening Links When a Node is Moved
Reply #1 - Sep 10th, 2013 at 5:45am
The links are straight lines by default, unless you change their Shape, Segments or AutoRoute properties.
If you want them shown as straight lines only while a node is being moved, you could disable AutoRoute and set SegmentCount = 1, Shape = Polyline from NodeStartModifying event hander (for each link in node.GetAllLinks()), and reset them back to their usual shape from NodeModified.
If you need the links straightened after a node is moved, set them to 1-segment polyline in NodeModified handler.
Paul
Reply #2 - Sep 10th, 2013 at 9:50pm
That's exactly what I was looking for. Thanks.
