Normal Topic How to draw custom shapes in diagramming (Read 4885 times)
Kiran B
Oct 2nd, 2013 at 7:46pm
How can i draw a custom shape in Diagramming in js/server side.
I need to draw a square inside a circle.
Kiran B
Re: How to draw custom shapes in diagramming
Reply #1 - Oct 3rd, 2013 at 10:38am
There is no official support for custom shapes yet in the MVC control, but this should work:
// on client side
Sys.Application.add_init(function (sender, args)
        new MindFusion.Diagramming.Shape({
            outline: 'A50,50,50,0,6.28318530717959,0 Z',
            decoration: 'M15,15 L85,15 L85,85 L15,85 L15,15 Z',
// on the server
Shape shape = new Shape(
new ElementTemplate[]
        new ArcTemplate(0, 0, 100, 100, 0f, 360f)
        new LineTemplate(15, 15, 85, 15),
        new LineTemplate(85, 15, 85, 85),
        new LineTemplate(85, 85, 15, 85),
        new LineTemplate(15, 85, 15, 15)
        new LineTemplate(-20, 100, 140, 100),
        new LineTemplate(140, 100, 140, 140),
        new LineTemplate(140, 140, -20, 140),
        new LineTemplate(-20, 140, -20, 100)
FillMode.Winding, "CircledRect"
Make sure the server-side shape definition comes before any FromJson calls.
Kiran B
Reply #2 - Oct 19th, 2013 at 6:24am
Hi Stoyan,
I tried the below code to add the new shape to nodelist view , but i am getting some JavaScript exception
var newShape = new MindFusion.Diagramming.Shape({
                 $find("nodelist1").addItem(newShape);
Exception:
Uncaught TypeError: Cannot read property 'outlinePath' of undefined
Kiran B
Reply #3 - Oct 19th, 2013 at 11:04am
You must add a ShapeNode instance to the NodeListView, and not a Shape:
var newNode = new MindFusion.Diagramming.ShapeNode();
newNode.setShape(newShape);
nodeListView.addItem(newNode);
Kiran B
Reply #4 - Oct 19th, 2013 at 7:52pm
Hi Stoyan,
Now the new item is coming in nodelistview, but i am not able to drag and drop that item to diagram canvas.
kiran B
Kiran B
Reply #5 - Oct 19th, 2013 at 11:51pm
Hi Stoyan,
I got the solution.
Need to add the below code also.
nodeListView.addBox(newNode);
Kiran B
Reply #6 - Oct 21st, 2013 at 6:23am
My mistake, sorry, addItem is actually a private method, you should call the documented addNode method:
nodeListView.addNode(newNode);
It calls several other methods internally: addItem, addBox and addCaption.
I hope that help,
