Normal Topic How we can draw the link by using Path returned by PathFinder (Read 4986 times)
Todkar
Oct 14th, 2013 at 7:10am
How we can draw the link by using Path returned by PathFinder ?
Does PathFinder helps to find out shortest path? if yes how we can use the same to draw the link?
it will good to understand if you provide me example.
I am working on latest version of Silverlight and mindfusion.
Jayraj
Re: How we can draw the link by using Path returned by PathFinder
Reply #1 - Oct 14th, 2013 at 9:22am
PathFinder returns the shortest graph-theoretic path: a list of nodes and links you need to pass through to get from origin node to target node. To find a geometric path for a link that does not cross other nodes, call the link.Route() method.
