Normal Topic Font is not serializing correctly (Read 2744 times)
Kiran B
Oct 16th, 2013 at 11:49am
We are setting the font for shapes as given below in client side while creating the node.
node.setFont(new MindFusion.Drawing.Font("Open Sans", 5, true, false));
But when it reaches the server and converting to xml its getting saved as Microsoft Sans Serif.
Coz of this while reloading the xml back to diagram the font is displaying differently.
Is there any fix for this?
Kiran B
Re: Font is not serializing correctly
Reply #1 - Oct 16th, 2013 at 12:20pm
Perhaps there is no Open Sans font available on the server and it falls back to Microsoft Sans Serif when creating the corresponding .NET Font object. Try setting font attributes through styles instead, the font name is saved only as string then and should not change after post-back.
Kiran B
Reply #2 - Oct 18th, 2013 at 10:39am
Hi Stoyan,
Could you please give me a sample to give the font using style attribute?
Kiran B
Reply #3 - Oct 18th, 2013 at 11:14am
var style = new Style();
style.setFontName("Open Sans");
style.setFontSize(5);
node.setStyle(style);
or call diagram.setStyle() to use that font for all nodes.
