Normal Topic Custom nodes in NodeListView (Read 1847 times)
Kiran B
Oct 24th, 2013 at 7:21pm
How can I add the custom shapes to NodeListView control and enable drag and drop functionality?
Kiran B
Re: Custom nodes in NodeListView
Reply #1 - Oct 25th, 2013 at 8:40am
You can add custom nodes only on the client side at this time, using the NodeListView.addNode method. Nodes should have a clone function implemented in order to enable drag-and-drop:
// in CustomNode prototype
clone: function ()
    var copy = CustomNode.callBaseMethod(this, "clone", []);
    copy.setLabel(this.label);
    copy.setNodeType(this.nodeType);
    return copy;
« Last Edit: Oct 25th, 2013 at 10:33am by Stoyo »
