Normal Topic DiagramLink does not remain anchored to node that are children inside a Rectangle Shape Node (Read 3221 times)
calace
Just WPF It
Oct 25th, 2013 at 3:21am
Why is it that the DiagramLink anchored to a ShapeNode within a group that has a Rectangle Shape Node as the Main item does not remain anchored when the ShapeNode.Move(x,y) is called programmatically. If you move the group manually, it is fine.
I used DynamicLink = true and it works most of the time but not always. It used to work in the old MindFusion version. 2.3.
Re: DiagramLink does not remain anchored to node that are children inside a Rectangle Shape Node
Reply #1 - Oct 25th, 2013 at 1:52pm
I suppose something has broken since 2.3. For the time being use this method as a work-around:
private void MoveGroup(DiagramNode mainNode, Point newPosition)
	Point oldPosition = mainNode.Bounds.Location;
	var ist = new InteractionState(mainNode, 8, Action.Modify);
	ist.Start(oldPosition, diagram);
	ist.Update(newPosition, diagram);
	ist.Complete(newPosition, diagram);
calace
Just WPF It
Reply #2 - Oct 25th, 2013 at 3:17pm
Thanks a lot for your quick help. Initial testing with the move of the node makes this behaviour similar to the 2.3 version.
Reply #3 - Oct 28th, 2013 at 11:43am
The Move method should update links to attached nodes correctly in this new v3.0.3 build:
https://mindfusion.eu/_beta/WpfDiagram303.zip
