Normal Topic Image Inside Custom Node (Read 2911 times)
Waterfiets
Oct 28th, 2013 at 9:52am
Hi there,
Is it possible to add a picture, lets say, a test.jpg inside a custom node? If so, could i get an example?
Greets,
Sander
Re: Image Inside Custom Node
Reply #1 - Oct 28th, 2013 at 11:40am
See the IconNodes sample project.
Waterfiets
Reply #2 - Oct 28th, 2013 at 11:59am
HI,
I've seen the project, but this isn't exactly what I'm looking for. This is an IconNode, or an icon that acts like a node. What i want is an icon in the custom nodes I've already created.
Thanks in advance.
Greets,
Sander
Reply #3 - Oct 28th, 2013 at 12:27pm
IconNode is a custom node class that implements custom ImageSource Icon property and draws that image from  the Draw override, which sounds the same as what you need. The ImageSource bitmaps can be loaded from files, resources, the Internet, or whatever. Check the NodeDoubleClicked handler in MainWindow.xaml.cs to see how images loaded from files are assigned to that custom property.
Waterfiets
Reply #4 - Oct 28th, 2013 at 1:52pm
It was kinda confusing at first but i finally figured it out, thanks! Cheesy
Greets,
Sander
« Last Edit: Oct 29th, 2013 at 10:44am by Waterfiets »
