Normal Topic End of Silverlight (Read 9047 times)
Patrik
End of Silverlight
Nov 25th, 2013 at 11:26am
Hi!
How/What will you do when Silverlight comes to an end, are you working on any replacement to Silverlight in Web applications?
/Patrik
Re: End of Silverlight
Reply #1 - Nov 25th, 2013 at 12:01pm
We already have an HTML5 Canvas version of the control here:
http://mindfusion.eu/jsdiagram.html
and ASP.NET /MVC versions that use the JavaScript library as front-end:
http://mindfusion.eu/netdiagram.html
http://mindfusion.eu/mvcdiagram.html
Patrik
Reply #2 - Apr 14th, 2014 at 11:47am
We have started to look into this but need to go to Silverlight 5 meanwhile. We have bought your DiagramLite 2.0 for Silverlight 4 and the question is if we need to buy the DiagramLite for Silverlight 5 or is that already included as upgrade in some way?
BR
/Patrik
Reply #3 - Apr 14th, 2014 at 1:29pm
We first added Silverlight 5 assemblies for the version 2.3 release. If you were on active maintenance at that time, you should have access to it from your account page at the clients area on our site. I think  you can use Silverlight 4 assemblies in Silverlight 5 applications anyway.
Mikael P
Reply #4 - Apr 24th, 2014 at 11:23am
Hi Stoyan,
(I'm Patriks colleague so I think it's ok that I "hi-jack" his thread  Grin)
Where can we find a trial for v.2.3? This in order to test our current code together with Silverlight 5.
Thanks in advance!
//Mikael
Reply #5 - Apr 24th, 2014 at 11:50am
Hi Mikael,
Judging by your email address, your company has a license for our ASP.NET diagram control with source code, so you should be able to rebuild the DiagramLite2010 solution included with it for Silverlight 5 (by changing target framework in project properties). If you have lost the code, you can now download it from your account page at http://clientsarea.eu/.
