Normal Topic RouteAllLinks () (Read 4792 times)
maor
RouteAllLinks ()
Mar 25th, 2009 at 8:54am
I have diagram with links that cross shapes.
I tried to use RouteAllLinks (), but not sucessed...
(diagramLight.RouteAllLinks();)
Re: RouteAllLinks ()
Reply #1 - Mar 25th, 2009 at 9:42am
Are there any large nodes in the background? If yes, set their Obstacle property to false.
maor
Reply #2 - Mar 25th, 2009 at 9:45am
I dont see Obstacle property in ShapeNode object.
Reply #3 - Mar 25th, 2009 at 1:54pm
This version adds the Obstacle property:
https://mindfusion.eu/_temp/diaglite_newprops.zip
maor
Reply #4 - Mar 25th, 2009 at 2:27pm
Now i'm see the property.
set it to false, but the link is still cross shapes.
Reply #5 - Mar 25th, 2009 at 2:49pm
You should set it to false only for background nodes if you are using ones, and not for all nodes in the diagram. If that's not the case, email us a saved diagram that shows the problem, and our developer will check what's the problem.
maor
Reply #6 - Mar 25th, 2009 at 2:56pm
I forgot the 'diagramLight.RouteLinks = true;'.
Now its works..
Now , how i'm use RoutingOptions?
Reply #7 - Mar 25th, 2009 at 3:02pm
For example:
diagram.RoutingOptions.GridSize = 10;
diagram.RoutingOptions.CrossingCost = 20;
