Hot Topic (More than 10 Replies) Contextmenu questions (Read 8814 times)
Waterfiets
Re: Contextmenu questions
Reply #15 - Jan 9th, 2014 at 7:42am
Hi Stoyan,
Yes the project is started from a static constructor. I will test your proposal this afternoon.
Greets,
Sander
Waterfiets
Reply #16 - Jan 9th, 2014 at 9:47am
Hi Stoyan,
Any suggestions on how to achieve this?
Greets,
Sander
Reply #17 - Jan 9th, 2014 at 10:42am
I don't know what you are trying to achieve Smiley If you have static initialization code in a separate assembly and want it to run after Application.Current exists, you could move that code to some kind of static Init() method, and call Init from the App instance constructor.
Waterfiets
Reply #18 - Jan 9th, 2014 at 10:59am
Ah, well actually i've tried that, but it gives the same error Shocked. Maybe its just possible in the way its setup.
Reply #19 - Jan 9th, 2014 at 1:45pm
It cannot give you the same error if called from the App constructor. In the stack trace check if it's not still called in static context from somewhere.
