Normal Topic Text in balloon tooltip got clipped (Read 1948 times)
Kyle Chen
Dec 18th, 2013 at 3:20pm
Hi Stoyan,
I noticed a minor issue about tooltip in diagram node. When I try to use balloon tooltip for nodes, the tooltip text will sometimes got clipped. It will be fine if I set TooltipControl.IsBalloon = false. However the tooltip itself will be too wide(it won't automatically adjust its width) and that's why I was trying the balloon style.
Please see attached picture.
Kyle
Re: Text in balloon tooltip got clipped
Reply #1 - Dec 18th, 2013 at 6:15pm
That seems to be a well-known bug in the tooltip control:
http://social.msdn.microsoft.com/Forums/en-US/b37c4e7f-573f-45b3-8c41-b9d70dd3e3...
http://lvs.codeplex.com/workitem/1480
http://www.autoitscript.com/forum/topic/123967-windows-system-tray-baloon-tip-te...
Try resetting IsBalloon from the tooltip's Popup event as here; I'm not sure if that solves the same problem though:
http://stackoverflow.com/questions/12882931/tooltip-isballoon-cancel-messes-up-s...
Kyle Chen
Reply #2 - Dec 20th, 2013 at 3:47pm
Hi Stoyan,
Thanks for you reply.
I took off the balloon tooltip. There's no good way to solve it. Hope MS can spend some time on it some day...though we all know we can't count on that.  Grin
Happy coming holidays!
Kyle
