Normal Topic DiagramView does not show horizontal scrollbar. (Read 2084 times)
Fred
Jan 2nd, 2014 at 1:40pm
I use a DiagramView to show a diagram in a Windows Form (Dock=Fill).
The Diagram associated with the DiagramView is "arranged" through a SpringLayout.
The Diagram is larger and higher than the Form. The DiagramView shows a vertical scrollbar bu no horizontal scrollbar even though DiagramView.Scrollbars=true and DiagramView.HScrollBar.Visible=true.
Is this a bug? The version is 6.0.2.23785
Thank you in advance for any help
Re: DiagramView does not show horizontal scrollbar.
Reply #1 - Jan 2nd, 2014 at 2:00pm
Try calling Diagram.ResizeToFitItems() after SpringLayout.Arrange(). The horizontal scrollbar range depends on the width of Diagram.Bounds, and ResizeToFitItems will make Bounds large enough to fit all nodes.
Fred
Reply #2 - Jan 2nd, 2014 at 2:27pm
Hello Stoyan,
Many thanks for your answer. This SOLVED my problem.
Best regards
Fred
