Normal Topic Extend ShapeNode text outside of shape's bounds (Read 2695 times)
GregC
Jan 16th, 2014 at 12:09pm
I am using WPF Diagramming.  I have a ShapeNode and I would like to show some text above the shape.  To do this I set TextPadding = new System.Windows.Thickness(0, -15, 0, 0).   This works fine.
However, if the length of text is wider than the node, i would like it to just continue on one line, rather than wrap when it reaches the right edge of the shape.  I tried TextWrapping = NoWrap, but this just makes the text disappear completely.  I also tried many other things.
Any workaround to achieve what i need ?
I attached an image to better explain.
Greg
Re: Extend ShapeNode text outside of shape's bounds
Reply #1 - Jan 16th, 2014 at 12:36pm
By that logic you can also extend the horizontal text region using negative Left and Right members of TextPadding:
var d = diagram.Factory.CreateShapeNode(110, 110, 50, 50);
d.TextPadding = new Thickness(-200000, -15, -200000, 0);
d.Text = "major major major major major major";
d.TextVerticalAlignment = AlignmentY.Top;
d.TextAlignment = TextAlignment.Center;
That works fine in my test project.
GregC
Reply #2 - Jan 16th, 2014 at 1:00pm
That works, thanks for the tip !  Seems obvious now.
Best Regards
Greg
