Normal Topic Invoke context menu (Read 8733 times)
ESKO
Invoke context menu
Jan 27th, 2014 at 9:34am
I wanna ask how can I invoke context menu by holding finger on diagramView?
I tried this:
Code (Java)
diagramView.setOnCreateContextMenuListener(new OnCreateContextMenuListener(){
			@Override
			public void onCreateContextMenu(ContextMenu menu, View v,
					ContextMenuInfo menuInfo) {
				MenuItem arrange = menu.add(Menu.NONE, 0, 0, "Arrange diagram");
but this doesn't work Undecided
Re: Invoke context menu
Reply #1 - Jan 27th, 2014 at 11:17am
Our guess is this does not work because DiagramView intercepts long clicks to toggle selection and the base View doesn't ever get to create a context menu. Our developer will try to add support for context menus in the next couple of days.
Reply #2 - Jan 28th, 2014 at 9:04pm
This version should display the context menu upon a long press:
https://mindfusion.eu/_beta/droiddiag_ctxmenu.zip
ESKO
Reply #3 - Jan 29th, 2014 at 5:58pm
thanks  Smiley
reedm60
Reply #4 - Oct 31st, 2018 at 8:11pm
Does anyone know how to create a context menu that comes up when a user (long) touches a diagram item?  The documentation talks about handling the onContextMenuOpening event but I don't know how to do that.
Thanks!
Reply #5 - Oct 31st, 2018 at 8:42pm
Check the "Controls" sample project, it shows custom context menu like this -
diagramView.getDiagram().addDiagramListener(new DiagramAdapter()
	@Override
	public void contextMenuOpening(RadialMenuEvent e)
		final DiagramItem diagramItem = e.getItem();
		e.getMenu().addMenuItem(R.drawable.square1,
			new MenuItemListener()
				public void onTouchUp(MenuItemEvent e)
					if (diagramItem instanceof ShapeNode)
						ShapeNode node = (ShapeNode)diagramItem;
						node.setShape(Shape.fromId("Rectangle"));
		e.getMenu().addMenuItem(R.drawable.circle1,
					if(diagramItem instanceof ShapeNode)
						node.setShape(Shape.fromId("Ellipse"));
reedm60
Reply #6 - Oct 31st, 2018 at 8:47pm
Thank you!!!
reedm60
Reply #7 - Oct 31st, 2018 at 9:57pm
Is there any way to replace the Radial style menu with a standard looking textual popup menu?
Reply #8 - Nov 1st, 2018 at 8:56am
Try calling RadialMenuEvent.setCancel(true) to prevent the radial menu from popping up, and then show whatever other UI you prefer.
reedm60
Reply #9 - Nov 1st, 2018 at 3:15pm
Thanks again.  I can see from decompiling the DiagramView code that calling setCancel() on the RadialMenuEvent will definitely keep it from displaying.
