Normal Topic MindFusion Pack for WPF 2014.R1 (Read 8590 times)
Jan 30th, 2014 at 8:26am
MindFusion Pack for WPF 2014.R1 has been released. It adds the following new features:
Visual Studio 2013 support
MindFusion Pack for WPF now includes support for Visual Studio 2013. The installer can create VS2013 toolbox palette for the components, and can optionally install VS2013 sample projects.
MindFusion.Diagramming
Import Visio 2013 files
The Visio2013Importer class can import .vsdx files, created by version 2013 of Microsoft Visio. In order to use it, you must add a reference to the MindFusion.Diagramming.Wpf.VisioImport.dll assembly. Various overloads of the Import method can be used to import the Visio drawing into a DiagramDocument whose pages correspond to the Visio pages, or into a single Diagram whose content is merged from all imported pages. When merging multiple pages, their positions in the diagram depend on the PagesPerRow value. Visio2013Importer supports Visio's basic flowchart and data flow stencils. For each node shape from the .vsdx file, the importer creates a ShapeNode object whose Shape, Text, Brush and Stroke properties are set to values corresponding to the imported Visio shape. For each connector shape, the importer creates a DiagramLink object whose Origin and Destination are set to the corresponding imported nodes, and whose ControlPoints reflect the geometry of the connector.
Zoom control
The ZoomControl class lets the users to interactively change the current zoom level and scroll position of a Diagram or DiagramView. To set it up, add a ZoomControl to the window, place it anywhere over the target diagram, and set the control's Target property to that diagram or view. Set the ZoomStep and ScrollStep properties to specify the amount added to view's zoom level or scroll position by ZoomControl's buttons. You can customize the control's appearance by setting properties such as Fill, Stroke, CornerRadius and TickPosition.
  • Enable the AllowRenamePages property of TabbedDiagramView to let users rename a DiagramPage interactively by clicking its tab.
  • Several new shapes added for better compatibility with Visio 2013 basic stencil: RightTriangle, Decagon, Trapezoid, Star4Pointed, Star5Pointed, Star6Pointed, Star7Pointed, Star16Pointed, Star24Pointed, Star32Pointed, Donut, Plaque.
  • DefaultEncoding and AutoDetectEncoding properties added to PdfExporter.
  • New RoundAndSquare and RoundAndSquare2 handle styles can be set as the HandlesStyle of nodes.
  • SkipEmptyPages property added to PrintOptions.
  • The projection of a node on the scales of Ruler control now shows the boundaries of the rotated node shape. To ignore rotation as in older versions, set ProjectRotatedBounds to false.
  • Fixed invisible inplace edit text-box problem under Windows 8 and .NET 4.5.
  • Fixed bug in undo/redo of RotationAngle assignments.
https://www.mindfusion.eu/WpfPackTrial.zip
