Normal Topic Event for insertion Item into ContainerNode (Read 2397 times)
Kuzya
Jan 30th, 2014 at 3:57pm
Which event reacts to insertion of several elements in containerNode?
If I select one element and insert in containerNode then event NodeModifying functioned.
If I of several elements insert in containerNode then event NodeModifying no reaction has.
Many thanks in advance
Kuzya
Re: Event for insertion Item into ContainerNode
Reply #1 - Jan 30th, 2014 at 4:47pm
Try ContainerChildAdded.
Kuzya
Reply #2 - Jan 31st, 2014 at 8:48am
Many thanks for your help.
But I would like to stop or to cancel the whole Prosses.
In the event  NodeModifying I can stop with the CancelDrag() the Prosses.
How do I make that with the ContainerChildAdded ?
Kind regards
Kuzya
Reply #3 - Jan 31st, 2014 at 10:19am
You cannot stop it from the ChildAdded event. You could handle SelectionMoving if you need to cancel for multiple selected items.
Kuzya
Reply #4 - Jan 31st, 2014 at 4:01pm
Hearty thanks for your help! Everything functions!
