Normal Topic Flip horizontal / vertical a node / shape (Read 2189 times)
Gabriel
Feb 12th, 2014 at 8:43am
I need to allow the user to flip horizontal / vertical a node.
Is there any easy way to do it?
Thank you
Gabriel
Re: Flip horizontal / vertical a node / shape
Reply #1 - Feb 12th, 2014 at 2:07pm
You could let users rotate shapes by setting EnabledHandles = All. Mirroring a shape by flipping the node's Bounds is not supported out of the box. You could create mirrored shapes dynamically using the Reverse method here:
http://mindfusion.eu/Forum/YaBB.pl?num=1333397142/3#3
and let users change them via context menu commands, or by tracking user interaction and changing node.Shape when you detect a side handle has been dragged over the opposite side.
Gabriel
Reply #2 - Feb 13th, 2014 at 7:47am
That solved the issue, thank you very much.
