Normal Topic Slow loading (Read 6737 times)
Damon
Slow loading
Feb 27th, 2014 at 2:44pm
Hi, I am trying to populate a worksheet with data, roughly 10k cells. This takes more than a minute. Is this normal or can I do something to speed the process?
Damon
Re: Slow loading
Reply #1 - Feb 27th, 2014 at 3:36pm
Try loading the cell data inside a BeginInit/EndInit block:
worksheet.BeginInit();
// Populate the worksheet here
worksheet.EndInit();
Let me know if this helps.
Damon
Re: Slow loading
Reply #2 - Feb 28th, 2014 at 11:44am
This helped, thanks
Damon
Damon
Re: Slow loading
Reply #3 - Mar 3rd, 2014 at 10:21am
I'm trying to save the above worksheet (~10k cells) in a file using savetofile, it takes around a minute. The BeginInit trick does't appear to help.
Damon
Re: Slow loading
Reply #4 - Mar 4th, 2014 at 12:20pm
We made some improvements to the binary serialization of the workbook. A new version of the control can be downloaded from the link below:
https://mindfusion.eu/_temp/MindFusion.Spreadsheet.trial.zip
Unfortunately, the new binary format is not backward compatible and any previously saved workbooks will not load.
I hope this helps.
Damon
Re: Slow loading
Reply #5 - Mar 6th, 2014 at 12:22pm
thank you
