Page Index Toggle Pages: [1] 2 3 ... 21 Send TopicPrint
Locked Topic Link between two nodes (Read 129568 times)
shrinivas
May 21st, 2014 at 6:15am
Can you tell me how to change the length of connectors between two nodes?
Re: Link between two nodes
Reply #1 - May 21st, 2014 at 7:04am
You can change link's length only indirectly by assigning new coordinates to link.ControlPoints. If you simply need the link to take shortest possible path between nodes, set its Shape to Polyline and SegmentCount = 1.
shrinivas
Reply #2 - May 21st, 2014 at 8:24am
I want consistent length of connectors between all nodes, here problem is some connectors are small and some are large.
here is code,
ShapeNode SrcShapeNode = DiagramView1.Diagram.FindNodeById(SourceNode) as ShapeNode;
ShapeNode DestShapeNode = DiagramView1.Diagram.FindNodeById(DestinationNode) as ShapeNode;
DiagramLink d = factory.CreateDiagramLink(SrcShapeNode, DestShapeNode);
Reply #3 - May 21st, 2014 at 8:29am
So you want to place nodes at equal distances, try running SpringLayout.Arrange to achieve that.
shrinivas
Reply #4 - May 21st, 2014 at 8:48am
Its working properly but some nodes are not visible cz of this change. and another one thing length is consistent but its to long i want consistent with short.
Reply #5 - May 21st, 2014 at 9:36am
Call diagram.ResizeToFitItems after Arrange.
Set smaller SpringLayout.NodeDistance value.
shrinivas
Reply #6 - May 22nd, 2014 at 9:18am
Can u tell me how to change color of connectors, I am using following code.
DiagramLink d1 = factory.CreateDiagramLink(SrcShapeNodeLoop,DestShapeNodeLoop);
d1.Brush = new MindFusion.Drawing.SolidBrush(System.Drawing.Color.Red);
But its not applying Red color.
Reply #7 - May 22nd, 2014 at 9:39am
Try with d1.Pen = new MindFusion.Drawing.Pen(System.Drawing.Color.Red, 0); The Brush property is used to fill arrowheads if they are closed shapes.
shrinivas
Reply #8 - May 22nd, 2014 at 9:55am
Thanks Its working can u tell me some list of syntax so that I can get help from there.
In programmers guide proper syntax is not present.
Reply #9 - May 22nd, 2014 at 10:39am
shrinivas
Reply #10 - May 22nd, 2014 at 11:44am
I am using following layout still some nodes are not visible.
MindFusion.Diagramming.Layout.CascadeLayout l2 = new MindFusion.Diagramming.Layout.CascadeLayout();
            l2.Arrange(diagram);
            diagram.ResizeToFitItems(10);
Reply #11 - May 22nd, 2014 at 12:42pm
Do you mean there are nodes outside of the diagram boundaries, and you cannot scroll to them?
shrinivas
Reply #12 - May 22nd, 2014 at 12:49pm
yes right
shrinivas
Reply #13 - May 22nd, 2014 at 1:36pm
How to give solid arrowhead for connectors?
How to change text orientation i.e vertical to horizontal and vice versa for text on connectors?
Reply #14 - May 22nd, 2014 at 5:59pm
Quote:
yes right
Check if you aren't setting a smaller diagram.Bounds value later; I can't see any way the ResizeToFit method would not set large enough diagram area.
Set link.HeadShape = Arrowheads.Triangle (or another closed shape from the enum).
Quote:
How to change text orientation i.e vertical to horizontal and vice versa for text on connectors.
If you are using ImageMap or JavaApplet mode, you could set link.TextStyle = LinkTextStyle.Rotate and the text will automatically follow the link direction. This is not supported in ClientSideMode=Canvas at this time.
