Page Index Toggle Pages: 1 ... 5 6 [7] 8 9 ... 21 Send TopicPrint
Locked Topic Link between two nodes (Read 157389 times)
Re: Link between two nodes
Reply #90 - Jun 13th, 2014 at 10:05am
Quote:
In decision layout problem in links, some are long and some are short
We honestly don't see anything wrong with some links being longer. If a loop link returns to the beginning of a 7-8 transitions long sequence of shorter links, the loop link obviously must be much longer.
Quote:
and link head is not proper
If you mean some links ending with triangles and other ones with arrowheads as in my last screenshot, it's up to you to select the shape by setting HeadShape property.
Quote:
also text shuffling is not solved.
We've discussed that before, try using LinkLabels to show texts near the beginning of links and it should be clear what link they belong to. In ImageMap mode you could also try ordinary Text with TextStyle = Rotate or Follow. We'll try to port these options to JavaScript for next release.
Quote:
Longer U-bends issue is still not resolved in your latest version.
They have been shortened, compare my last screenshot with the one from post #28: http://mindfusion.eu/_samples/dl.png
shrinivas
Reply #91 - Jun 13th, 2014 at 1:27pm
I am using TextStyle = Rotate or Follow but still is shuffled and Your not getting what exactly I mean see the links in attached diagram, Link betwwen VID-D-MESSAGE =' ' to VID-D-FKEYS ='F3=Exit F4=Change F12=Cancel' is very small in length which not appropriate.
see the arrow in red square which is not proper.
Vidp3x-processRentalMap_001.pdf (Attachment deleted)
Reply #92 - Jun 13th, 2014 at 4:47pm
They are not supported in Canvas mode (ClientSideMode property) at this time, try switching to ImageMap or use LinkLabels.
Increase the node distance by setting larger HorizontalPadding and VerticalPadding property values of DecisionLayout, then the arrowheads should fit. Or if you prefer the shorter node distance, then set smaller DiagramLink.HeadShapeSize.
shrinivas
Reply #93 - Jun 17th, 2014 at 12:44pm
I am getting following error while displaying flowchart on asp page.
Sys.ArgumentException: Cannot deserialize. The data does not correspond to valid JSON
XML is properly loaded in diagram control but after that pointer moves outside the function and then occurs above error.
Can u tell me any best way to solve these kind of errors?.
I have attached XML file please check and let me know if any wrong in that.
Thank You.
IN0310-addModeStandardPromptingSequence100.txt (Attachment deleted)
Reply #94 - Jun 17th, 2014 at 1:26pm
Are you using Canvas mode now? The diagram loads correctly in the browser from my test project. Could you copy the json string value shown by browser's debugger and attach it here? You should be able to access it from the 'json' argument of Diagram.fromJson function in the call-stack.
shrinivas
Reply #95 - Jun 18th, 2014 at 4:53am
Yes I am using Canvas mode,
JSON argument value :
function Sys$UI$Control$get_element() {
        /// <value domElement="true" locid="P:J#Sys.UI.Control.element"></value>
        if (arguments.length !== 0) throw Error.parameterCount();
        return this._element;
Reply #96 - Jun 18th, 2014 at 4:53am
If you are seeing this problem only with large diagrams, check if there isn't some small value set for maxRequestLength in web.config. The diagram control uses a hidden field to transfer the json data as in this post:
http://stackoverflow.com/questions/15641311/is-there-any-limit-to-hidden-field-l...
Reply #97 - Jun 18th, 2014 at 5:31am
That doesn't look plausible. You should see a Diagram.fromJson function in the callstack window when the exception is thrown. If you double click on it and add its argument to the watch window, what value does it show there? In the minified script the argument will be called something like A actually, here's what I'm seeing if I call fromJson manually with a bogus string and the IEs debugger stops on throw:
shrinivas
Reply #98 - Jun 18th, 2014 at 6:10am
Please check attachment.
Reply #99 - Jun 18th, 2014 at 6:18am
Ok, and what's the data argument value at that point?
shrinivas
Reply #100 - Jun 18th, 2014 at 7:52am
{"id":"DiagramView1","width":{"IsEmpty":false,"Type":1,"Value":1150},"height":{"
IsEmpty":false,"Type":1,"Value":550},"diagramBounds":{"x":-10,"y":-10,"width":57
2,"height":1622},"enabled":true,"measureUnit":6,"allowInplaceEdit":false,"items"
:[{"__type":"MindFusion.Diagramming.ShapeNode","zIndex":0,"tag":null,"selected":false,"visible":true,"id":"1","ignoreLayout":false,"locked":false,"tooltip":"","hyperLink":"","shadowOffsetX":1,"shadowOffsetY":1,"brush":{"type":"SolidBrush","color":"#FFCC00"},"pen":null,"textColor":null,"shadowColor":null,"font":null,"style":null,"instanceId":0,"bounds":{"x":12,"y":12,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPattern":null,"expanded":true,"expandable":false,"allowIncomingLinks":true,"allowOutgoingLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"Business Rule IF1000","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"
rotateText":false,"rotateImage":true},{"__type":"MindFusion.Diagramming.ShapeNod
e","zIndex":0,"tag":null,"selected":false,"visible":true,"id":"2","ignoreLayout"
tY":1,"brush":{"type":"SolidBrush","color":"#00CCFF"},"pen":null,"textColor":nul
l,"shadowColor":null,"font":null,"style":null,"instanceId":1,"bounds":{"x":12,"y
":32,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPatter
ingLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"TRUE =1","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rota
teText":false,"rotateImage":true},{"__type":"MindFusion.Diagramming.ShapeNode","
zIndex":0,"tag":null,"selected":false,"visible":true,"id":"3","ignoreLayout":fal
1,"brush":{"type":"SolidBrush","color":"#00CCFF"},"pen":null,"textColor":null,"s
hadowColor":null,"font":null,"style":null,"instanceId":2,"bounds":{"x":12,"y":52
inks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"FALSE =0","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rota
zIndex":0,"tag":null,"selected":false,"visible":true,"id":"4","ignoreLayout":fal
hadowColor":null,"font":null,"style":null,"instanceId":3,"bounds":{"x":12,"y":72
inks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"OTHERWISE =TRUE","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"r
otateText":false,"rotateImage":true},{"__type":"MindFusion.Diagramming.ShapeNode
","zIndex":0,"tag":null,"selected":false,"visible":true,"id":"5","ignoreLayout":
Y":1,"brush":{"type":"SolidBrush","color":"#00CCFF"},"pen":null,"textColor":null
,"shadowColor":null,"font":null,"style":null,"instanceId":4,"bounds":{"x":12,"y"
:92,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPattern
ngLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"MAYBE =2","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rota
zIndex":0,"tag":null,"selected":false,"visible":true,"id":"6","ignoreLayout":fal
hadowColor":null,"font":null,"style":null,"instanceId":5,"bounds":{"x":12,"y":11
Links":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"ASK =3","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rota
zIndex":0,"tag":null,"selected":false,"visible":true,"id":"7","ignoreLayout":fal
hadowColor":null,"font":null,"style":null,"instanceId":6,"bounds":{"x":12,"y":13
Links":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"AM =AM","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rot
ateText":false,"rotateImage":true},{"__type":"MindFusion.Diagramming.ShapeNode",
"zIndex":0,"tag":null,"selected":false,"visible":true,"id":"8","ignoreLayout":fa
:1,"brush":{"type":"SolidBrush","color":"#00CCFF"},"pen":null,"textColor":null,"
shadowColor":null,"font":null,"style":null,"instanceId":7,"bounds":{"x":12,"y":1
52,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPattern"
gLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"VM =VM","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rot
"zIndex":0,"tag":null,"selected":false,"visible":true,"id":"9","ignoreLayout":fa
shadowColor":null,"font":null,"style":null,"instanceId":8,"bounds":{"x":12,"y":1
72,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPattern"
gLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"SM =SM","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rot
"zIndex":0,"tag":null,"selected":false,"visible":true,"id":"10","ignoreLayout":f
":1,"brush":{"type":"SolidBrush","color":"#00CCFF"},"pen":null,"textColor":null,
"shadowColor":null,"font":null,"style":null,"instanceId":9,"bounds":{"x":12,"y":
192,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPattern
ngLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"CR =CHAR ( 13)","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rot
"zIndex":0,"tag":null,"selected":false,"visible":true,"id":"12","ignoreLayout":f
"shadowColor":null,"font":null,"style":null,"instanceId":10,"bounds":{"x":12,"y"
:212,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPatter
ingLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"LF =CHAR ( 10)","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rot
"zIndex":0,"tag":null,"selected":false,"visible":true,"id":"14","ignoreLayout":f
"shadowColor":null,"font":null,"style":null,"instanceId":11,"bounds":{"x":12,"y"
:232,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPatter
ingLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"MEG =1000000","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1
,"rotateText":false,"rotateImage":true},{"__type":"MindFusion.Diagramming.ShapeN
ode","zIndex":0,"tag":null,"selected":false,"visible":true,"id":"15","ignoreLayo
fsetY":1,"brush":{"type":"SolidBrush","color":"#00CCFF"},"pen":null,"textColor":
null,"shadowColor":null,"font":null,"style":null,"instanceId":12,"bounds":{"x":1
2,"y":252,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorP
OutgoingLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"Set prompt character equal to "" \r\n ","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rotate
Text":false,"rotateImage":true},{"__type":"MindFusion.Diagramming.ShapeNode","zI
ndex":0,"tag":null,"selected":false,"visible":true,"id":"16","ignoreLayout":fals
,"brush":{"type":"SolidBrush","color":"#33CCCC"},"pen":null,"textColor":null,"sh
adowColor":null,"font":null,"style":null,"instanceId":13,"bounds":{"x":12,"y":27
2,"width":80,"height":90},"enabledHandles":511,"handlesStyle":1,"anchorPattern":
Links":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Decision","imageLocation":"","text":"Open DATASET  "INTERFACE" \r\n  to file variable  For_Flat_File_Dumps_of_Interface_Data_Coming_in \r\n ?\r\n","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"r
","zIndex":0,"tag":null,"selected":false,"visible":true,"id":"18","ignoreLayout"
l,"shadowColor":null,"font":null,"style":null,"instanceId":14,"bounds":{"x":12,"
y":377,"width":80,"height":20},"enabledHandles":511,"handlesStyle":1,"anchorPatt
goingLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"Display Message of "CANNOT \r\n OPEN INTERFACE FILE!"  to \r\n console","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,
"rotateText":false,"rotateImage":true},{"__type":"MindFusion.Diagramming.ShapeNo
de","zIndex":0,"tag":null,"selected":false,"visible":true,"id":"19","ignoreLayou
setY":1,"brush":{"type":"SolidBrush","color":"#00CCFF"},"pen":null,"textColor":n
ull,"shadowColor":null,"font":null,"style":null,"instanceId":15,"bounds":{"x":12
,"y":412,"width":80,"height":10},"enabledHandles":511,"handlesStyle":1,"anchorPa
utgoingLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Rectangle","imageLocation":"","text":"Stop processing and exit program \r\n  ","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rotate
ndex":0,"tag":null,"selected":false,"visible":true,"id":"20","ignoreLayout":fals
adowColor":null,"font":null,"style":null,"instanceId":16,"bounds":{"x":102,"y":2
87,"width":80,"height":60},"enabledHandles":511,"handlesStyle":1,"anchorPattern"
gLinks":true,"obstacle":true,"rotationAngle":0,"effects":[],"shape":"Decision","imageLocation":"","text":"Open DATASET  "SC.FLE" \r\n  to file variable  System_Control_File \r\n ?","textAlignment":1,"lineAlignment":1,"transparent":false,"imageAlign":1,"rotat
eText":false,"rotateImage":true},{"__type":"MindFusion.Diagramming.ShapeNode","z
Index":0,"tag":null,"selected":false,"visible":true,"id":"22","ignoreLayout":fal
hadowColor":null,"font":null,"style":null,"instanceId":17,"bounds":{"x":102,"y":
377,"width":80,"height":20},"enabledHandles":511,"handlesStyle":1,"anchorPattern
Reply #101 - Jun 18th, 2014 at 8:17am
The Json seems cut at the Display Message... text of some node. There is no such text in the IN0310-addModeStandardPromptingSequence100 XML you attached last, please attach the XML for this diagram, or post the full text of that node.
shrinivas
Reply #102 - Jun 18th, 2014 at 8:37am
Okay.
I have attached both files i.e XML and data file.
Data.txt (Attachment deleted)
IF1000-if1000.TXT (Attachment deleted)
Reply #103 - Jun 18th, 2014 at 10:48am
It seems to happen because of the &amp;quot; values in texts. MS.Ajax 4 loads it successfully even with them, but older 3.5 version throws the Sys.ArgumentException, so our guess is that was a Json serialization bug in older versions of the Ajax library. Anyway if you want to display quotes in node texts, replace all &amp;quot; instances in the XML with just &quot; and then it will work with both v3.5 and 4 of MS.Ajax.
shrinivas
Reply #104 - Jun 18th, 2014 at 12:37pm
I have added Ajax 4.0 versions DLL still same problem.
Can u send me link from which I can download Ajax 4.0 DLL.
