Page Index Toggle Pages: 1 ... 6 7 [8] 9 10 ... 21 Send TopicPrint
Locked Topic Link between two nodes (Read 157310 times)
Re: Link between two nodes
Reply #105 - Jun 18th, 2014 at 1:49pm
Check if you aren't explicitly loading MicrosoftAjax.js via <script> tag. If so - remove it, and add an <asp:ScriptManager> to the page, which loads corresponding ajax scripts automatically.
Note that &amp;quot; in your current XML will show as &quot; in the node texts instead of " symbol. Change it to just &quot; when generating XML to see " in texts, and it will work with Ajax v3.5 too then.
shrinivas
Reply #106 - Jun 20th, 2014 at 4:06am
No, I am not using MicrosoftAjax.js via <script> tag.
actually its not possible to change &amp;quot; to &quot; because i m encoding quotes (").
Code:
<asp:ScriptManager ID="ScriptManager1" runat="server">
</asp:ScriptManager>
Reply #107 - Jun 20th, 2014 at 7:49am
XML-encoded quote (") is just &quot; so put that in your XML or you will not see " in the nodes otherwise. With &amp;quot; you are trying to both xml- and html- encode it, but the JsonSerializer does its own html encoding so you don't need to add ampersands. If you insist on generating the XML yourself, at least use the .NETs XML API and pass plain un-encoded text values to its methods, they will apply necessary encodings.
shrinivas
Reply #108 - Jun 23rd, 2014 at 5:08am
Can u send me link from which I can download Ajax 4.0 DLL.
because in previous comments you said it works properly in 4.0
shrinivas
Reply #109 - Jun 23rd, 2014 at 6:36am
I want draw flowchart like below screen shots and there is (+) expand button for each square when i click on that button it expands and displays actual flowchart.
Can you send some details as well as sample codes to draw like that.
Reply #110 - Jun 23rd, 2014 at 8:38am
Quote:
Can u send me link from which I can download Ajax 4.0 DLL. because in previous comments you said it works properly in 4.0
You do not need the Ajax 4 dlls, you need to fix your XML. Content like &amp;quot; in the XML file is xml-unescaped to &quot; in the node texts, and I think you want to show " symbols instead to your users. To get " symbols, replace &amp;quot; with &quot; in the XML file, and Json serialization will work with either version of MS.Ajax.
If you really want to show &quot; to your users, then keep &amp;quot; in the XML, and change the project target framework from project options to ASP.NET 4 to use MS.Ajax 4.
« Last Edit: Jun 23rd, 2014 at 9:47am by Stoyo »
Reply #111 - Jun 23rd, 2014 at 10:34am
Try adding the nodes from separate flowcharts to a ContainerNode by calling ContainerNode.Add(childNode). Set the container's Foldable property to true to let users expand / collapse it.
shrinivas
Reply #112 - Jun 24th, 2014 at 4:50am
Okay fine can u send me sample XML file so that i can built in that way....
Reply #113 - Jun 24th, 2014 at 7:43am
You can find attached your file with all &amp;quot; replaced with &quot; it loads successfully under ASP.NET 3 too.
« Last Edit: Jun 24th, 2014 at 9:19am by Stoyo »
IF1000-if1000_001.TXT (Attachment deleted)
shrinivas
Reply #114 - Jun 24th, 2014 at 1:15pm
shrinivas wrote on Jun 23rd, 2014 at 6:36am:
Please see this i am not able to use container node for this please send me XML format from which i can generate this type of diagram.
shrinivas
Reply #115 - Jun 25th, 2014 at 5:03am
Can u please send me sample XML for attached diagram
Reply #116 - Jun 25th, 2014 at 8:20am
You can create sample xml by calling the SaveToXml method:
var container = diagram.Factory.CreateContainerNode(0, 0, 100, 100);
var child1 = diagram.Factory.CreateShapeNode(10, 10, 30, 30);
container.Add(child1);
var child2 = diagram.Factory.CreateShapeNode(50, 50, 30, 30);
container.Add(child2);
diagram.Factory.CreateDiagramLink(child1, child2);
var outerNode = diagram.Factory.CreateShapeNode(110, 10, 30, 30);
diagram.SaveToXml("test.xml");
test_xml.txt (Attachment deleted)
shrinivas
Reply #117 - Jun 26th, 2014 at 4:58am
For this type of diagram which layout is suitable?
Reply #118 - Jun 26th, 2014 at 10:26am
Try LayeredLayout with EnforceLinkFlow property enabled.
shrinivas
Reply #119 - Jun 26th, 2014 at 11:04am
No its not working with layered layout, please see attached image
