Page Index Toggle Pages: 1 ... 7 8 [9] 10 11 ... 21 Send TopicPrint
Locked Topic Link between two nodes (Read 157330 times)
shrinivas
Re: Link between two nodes
Reply #120 - Jun 27th, 2014 at 2:43pm
please reply ASAP to my last post.
shrinivas
Reply #121 - Jun 30th, 2014 at 4:03am
I have created attached XML and loaded using diagram object so its not displaying 'container node', Please check..
s2tadmin_ProgramFlow_Vidp1x_27Jun2014_030440PM.txt (Attachment deleted)
Reply #122 - Jun 30th, 2014 at 5:03am
Quote:
No its not working with layered layout, please see attached image
Set LayeredLayout.NodeDistance larger than your nodes.
Reply #123 - Jun 30th, 2014 at 6:24am
The container element must by a child of the Nodes element in XML. The group object only references it by ID.
shrinivas
Reply #124 - Jul 1st, 2014 at 5:33am
Can u tell me how to apply soft bends to connectors (LINK).
Reply #125 - Jul 1st, 2014 at 7:45am
Set RoundedLinks and RoundedLinksRadius properties of diagram.
shrinivas
Reply #126 - Jul 1st, 2014 at 8:15am
Following is code for loading XML and viewing diagram, As per your last comment i have applied riundedlinks and roundedlinkradius but still there is no change in diagram.
sFileName = Request.QueryString[0];
            DiagramView1.Diagram = new Diagram();
            DiagramView1.LoadFromXml(Server.MapPath(sFileName));
            DiagramView1.Diagram.RoundedLinks = true;
            DiagramView1.Diagram.RoundedLinksRadius = 10;
            MindFusion.Diagramming.Layout.LayeredLayout dl = new MindFusion.Diagramming.Layout.LayeredLayout();
            dl.Orientation = MindFusion.Diagramming.Layout.Orientation.Vertical;
            dl.EnforceLinkFlow = true;
            dl.LayerDistance = 10;
            dl.NodeDistance = 70;
            DiagramView1.CanvasVirtualScroll = true;
            dl.Arrange(DiagramView1.Diagram);
            DiagramView1.Diagram.ResizeToFitItems(10);
shrinivas
Reply #127 - Jul 1st, 2014 at 9:09am
How did you decide link between 2 nodes is from center of 2 nodes or at left side or at bottom side, what data you need for that.
shrinivas
Reply #128 - Jul 1st, 2014 at 10:18am
I am using following code but its not reflecting as I want, It means no change in linking there is no presence of Jump.
            DiagramView1.Diagram.RoundedLinksRadius = 2;
            DiagramView1.Diagram.LinkCrossings = LinkCrossings.Arcs;
Reply #129 - Jul 1st, 2014 at 10:21am
You will see a change only if the links contained any bends with the old code. With LayeredLayout links between adjacent layers are always straight lines and do not contain any bends; in that case you will see rounded bends only for links that are at least three-layers long, where their segments meet in intermediate layers.
You could control that via node.AnchorPattern property. Set it to TopInBottomOut for example to center all in/out links at respective node side.
Reply #130 - Jul 1st, 2014 at 10:23am
Both RoundedLinks and LinkCrossings were implemented in a recent release for Canvas mode:
http://mindfusion.eu/Forum/YaBB.pl?num=1396253277
Verify if you are using latest version of the diagramming.js file.
shrinivas
Reply #131 - Jul 1st, 2014 at 11:18am
Js file is latest, Please check attached file.
shrinivas
Reply #132 - Jul 1st, 2014 at 11:22am
Can you tell me its XML representation so that i can add those tags to XML.
Reply #133 - Jul 2nd, 2014 at 7:47am
Here's what I'm seeing with following code:
diagram.RoundedLinks = true;
diagram.RoundedLinksRadius = 5;
diagram.LinkCrossings = LinkCrossings.Arcs;
var n = diagram.Nodes;
for (int i = 0; i < 10; i++)
	diagram.Factory.CreateShapeNode(0, 0, 10, 10);
	for (int j = 0; j < i; j++)
		diagram.Factory.CreateDiagramLink(n[j], n[i]);
new LayeredLayout().Arrange(diagram);
If it does not show bridges and rounded bends for you, maybe your browser loads an older diagramming.js from cache. Try clearing the browser cache and run again to verify. Also your script file is a few days older than the one from our last official release, I suppose you are using some pre-release build. Try the official 5.2 version from http://mindfusion.eu/Forum/YaBB.pl?num=1403100114
shrinivas
Reply #134 - Jul 3rd, 2014 at 4:40am
I am applying white color to diagram background using backbrush property still its nt white when exported to PDF format.
<ndiag:DiagramView ID="DiagramView1" runat="server" Height="550px" Width="1150px"
                ClientIDMode="AutoID"  ClientSideMode="Canvas" Behavior="Modify"
                 BackColor="White" OverviewFitAll="True">
                <Diagram ShapeBrush="s:#FFFFFFFF" BackBrush="s:#FFFFFFFF" />
</ndiag:DiagramView>
