Page Index Toggle Pages: 1 ... 10 11 [12] 13 14 ... 21 Send TopicPrint
Locked Topic Link between two nodes (Read 157275 times)
Re: Link between two nodes
Reply #165 - Jul 8th, 2014 at 6:35am
For arrowhead outline, set HeadPen:
<HeadPen>
    <Color>#FFFF0000</Color>
    <DashOffset>0</DashOffset>
    <DashStyle>0</DashStyle>
    <LineJoint>0</LineJoint>
    <MiterLimit>10</MiterLimit>
    <Width>0</Width>
</HeadPen>
For fill color it's the Brush property, in same format as nodes.
shrinivas
Reply #166 - Jul 8th, 2014 at 9:27am
Stoyo wrote on Jul 8th, 2014 at 5:27am:
var point = new PointF(0, 0);
var link = diagram.Factory.CreateDiagramLink(point, point);
link.Pen = new Pen(Color.Red, 0);
diagram.SaveToXml("test.xml");
creates the following XML:
<Link Class="std:DiagramLink" Id="0" Version="2">
  <Pen>
    <Width>0</Width>
  </Pen>
For Dash lines what will be the value of <DashStyle>0</DashStyle> ?
Reply #167 - Jul 8th, 2014 at 9:31am
Try with 1.
shrinivas
Reply #168 - Jul 8th, 2014 at 9:40am
Stoyo wrote on Jul 8th, 2014 at 9:31am:
Try with 1.
Tried with 1 but its not coming.
Reply #169 - Jul 8th, 2014 at 9:51am
Actually the HTML Canvas element does not support drawing dashed lines yet, so you won't see them in NetDiagram's Canvas mode. They should render fine in the other modes.
shrinivas
Reply #170 - Jul 8th, 2014 at 10:51am
Stoyo wrote on Jul 8th, 2014 at 9:51am:
Okay.
shrinivas
Reply #171 - Jul 9th, 2014 at 4:44am
I have attached XML with PDF, Is any ways to minimize crossings and improve layout.
I am using your given code with orthogonal layout.
XMLwithPDF_001.zip (Attachment deleted)
Reply #172 - Jul 9th, 2014 at 3:56pm
At first glance setting ol.MinimizeLinkBends = false seems to create less crossings, at the cost of larger layout area. We'll try to improve it when enabled for next release.
shrinivas
Reply #173 - Jul 10th, 2014 at 4:16am
when I am trying
var layout = new MindFusion.Graphs.LayeredLayout();
Its giving error assembly missing even added js file.
MindFusion_Diagramming_js_001.zip (Attachment deleted)
Reply #174 - Jul 10th, 2014 at 5:27am
Are you calling this from JavaScript on client side or C# on server?
shrinivas
Reply #175 - Jul 10th, 2014 at 5:46am
Stoyo wrote on Jul 10th, 2014 at 5:27am:
In C#
Reply #176 - Jul 10th, 2014 at 5:59am
It's in MindFusion.Diagramming.Layout namespace:
var layout = new MindFusion.Diagramming.Layout.LayeredLayout();
shrinivas
Reply #177 - Jul 10th, 2014 at 6:05am
Actually I got this code from your team but its not working i mean compiler time errors,
Adding this code to C#.
var diagram = $find("diagram");
var AnchorPattern = MindFusion.Diagramming.AnchorPattern;
var ioPattern = new AnchorPattern(
   new AnchorPoint(0, 50, true, true, MarkStyle.None),
   new AnchorPoint(100, 50, true, true, MarkStyle.None)
for (var n = 0; n < diagram.nodes.length; n++)
   var node = diagram.nodes[n];
   node.setAnchorPattern(ioPattern);
var layeredLayout = MindFusion.Graphs.LayeredLayout;
layout = new layeredLayout();
layout.direction = MindFusion.Graphs.LayoutDirection.LeftToRight;
layout.nodeDistance = 8;
layout.layerDistance = 20;
layout.anchoring = MindFusion.Graphs.Anchoring.Reassign;
diagram.arrange(layout);
This should avoid crossings, but if you still want to bend the links, call
their route() method after arrange -
for (var l = 0; l < diagram.links.length; l++)
   var link = diagram.links[l];
   link.route();
Reply #178 - Jul 10th, 2014 at 6:09am
That's JavaScript code to call from client side scripts, it won't look exactly the same in C#.
shrinivas
Reply #179 - Jul 11th, 2014 at 4:14am
I have attached XML, VISIO and PDF.
There is problem in VISIO files again here smooth bends are not present and crossing of links.
XML_Visio_PDF.zip (Attachment deleted)
