Normal Topic How to get the DecorationHitTesting to work? (Read 2429 times)
mihai
Jul 28th, 2014 at 7:23pm
I have a shape with an outline and some decorations, that I'd like to be part of hit testing, so that I can create links by clicking on them. If I understand correctly, setting the DecorationHitTesting property to "true" on the shape should do what I need, but for some reason it doesn't. Thoughts?
By the way, the shape nodes are part of containers, although that shouldn't be an issue I think (I didn't see a difference when dragging them outside of the containers).
-Mihai
mihai
Re: How to get the DecorationHitTesting to work?
Reply #1 - Jul 28th, 2014 at 7:26pm
Also, what is the meaning of "near" in the docs: "If this property is enabled, users are able to select shape nodes of such shape by clicking near a decoration line or curve, even if it lies outside the shape outlines."? Is it customizable?
Thanks again,
-Mihai
Reply #2 - Jul 29th, 2014 at 7:34am
This seems to happen if you use a Shape with no string identifier defined, which makes it private for the node and the Shape property setter clones it. Apparently the Shape.Clone code does not copy DecorationHitTesting value at this time, so you could set it after assigning to node.Shape as a work-around:
shape.Shape = myShape;
shape.Shape.DecorationHitTesting = true;
"near" is fixed 5 millimeters, we could add a property for next release if you need it.
mihai
Reply #3 - Jul 29th, 2014 at 10:29am
Hi Stoyan,
Will this be fixed in the next release?
Thanks, it works!
Now that I see it in action, I think 5 mm is a good choice.
-Mihai
Reply #4 - Jul 29th, 2014 at 11:09am
Sure, it's now fixed in this build:
https://mindfusion.eu/_beta/wpfdiag32.zip
mihai
Reply #5 - Aug 4th, 2014 at 8:43am
Thanks Stoyan!
