Hot Topic (More than 10 Replies) Exception: Layout measurement ... should not return NaN values as its DesiredSize (Read 8336 times)
mihai
Aug 22nd, 2014 at 1:24pm
I'm having an issue with the OrthogonalRouter throwing exceptions after a few Arrange calls to route the links. The exception is:
System.InvalidOperationException
"Layout measurement override of element 'MindFusion.Diagramming.Wpf.DiagramLink' should not return NaN values as its DesiredSize."
with the following call stack:
   at System.Windows.UIElement.Measure(Size availableSize)
   at A.A.MeasureOverride(Size availableSize)
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at MindFusion.Diagramming.Wpf.Diagram.MeasureOverride(Size availableSize)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV, Boolean& hasDesiredSizeUChanged)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at System.Windows.Documents.AdornerDecorator.MeasureOverride(Size constraint)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at System.Windows.Window.MeasureOverrideHelper(Size constraint)
   at System.Windows.Window.MeasureOverride(Size availableSize)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
   at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork()
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
   at System.Windows.Threading.Dispatcher.Run()
   at System.Windows.Application.RunDispatcher(Object ignore)
   at System.Windows.Application.RunInternal(Window window)
   at System.Windows.Application.Run(Window window)
   at System.Windows.Application.Run()
   at Test.App.Main() in ...Test\obj\x86\Debug\App.g.cs:line 0
   at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
   at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
   at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
   at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
   at System.Threading.ThreadHelper.ThreadStart()
Any ideas?
Best Regards,
-Mihai
Re: Exception: Layout measurement ... should not return NaN values as its DesiredSize
Reply #1 - Aug 22nd, 2014 at 4:28pm
Could you attach diagram's xml file saved before calling OrthogonalRouter?
mihai
Reply #2 - Aug 22nd, 2014 at 7:01pm
Not easily (NDA / confidential), unless I strip it down a lot. Is there no other way to attack this?
Reply #3 - Aug 25th, 2014 at 7:36am
We'll need the node positions and connections for debugging this. Stripping down the confidential data should be a matter of setting a few properties, e.g.
foreach (var item in diagram.Items)
	item.Text = "";
	item.ToolTip = "";
	item.Tag = null;
diagram.SaveToXml("debug.xml");
unless the diagram drawing itself shows some secret plan...
mihai
Reply #4 - Aug 25th, 2014 at 7:52am
It's the diagram itself that's confidential.
Reply #5 - Aug 25th, 2014 at 9:43am
Measured size might be NaN if any link control point has a NaN coordinate. Try looping over all links immediately after Arrange call and check the ControlPoints values, can you find any link point with a NaN value for X or Y?
mihai
Reply #6 - Aug 25th, 2014 at 11:46am
Hi Stoyan,
Yes, I am able to find a couple of links with NaN(s) like the following:
link.ControlPoints.Count	6	int
link.ControlPoints[0]	{624,244094488189;498,263779527559}	System.Windows.Point
link.ControlPoints[1]	{626,744094488189;498,263779527559}	System.Windows.Point
link.ControlPoints[2]	{626,744094488189;902,763779527559}	System.Windows.Point
link.ControlPoints[3]	{NaN;NaN}	System.Windows.Point
link.ControlPoints[4]	{NaN;462}	System.Windows.Point
link.ControlPoints[5]	{634,244094488189;462}	System.Windows.Point
What next?
-Mihai
Reply #7 - Aug 25th, 2014 at 3:43pm
We've doubled-checked the OrthogonalRouter code and can't see anything that would create NaN values, unless some of the input nodes have NaN coordinates. Can you find any nodes that have NaNs in their Bounds?
mihai
Reply #8 - Aug 25th, 2014 at 6:58pm
Thanks for checking. There seem to be no nodes with NaN(s) in their Bounds.
But by the way, I can't get the OrthogonalRouter to produce the output I'm after, so maybe if that is addressed, the exception will go away. So let me detail:
  • I have a very tall node, with several small nodes at its right side, arranged in a couple of columns
  • Most of the small nodes are connected to the tall node
I would like the links to have the shortest possible length, say horizontally to the tall node's right edge. Instead, the links go around the tall node, although they could easily go straight without crossing each-other, or any other nodes for that matter.
Here are the parameters for the router:
var router = new OrthogonalRouter()
    Anchoring = Anchoring.Keep,
    EndOrientation = MindFusion.Diagramming.Wpf.Orientation.Horizontal,
    StartOrientation = MindFusion.Diagramming.Wpf.Orientation.Horizontal,
    NodeDistance = 0
What could I be doing wrong?
Reply #9 - Aug 26th, 2014 at 6:43am
OrthogonalRouter distributes link along the full perimeter of nodes in order to leave more space between them. If you prefer simple straight lines between the nodes when possible, try using the ArrangeLinks method from SequenceDiagram sample project.
mihai
Reply #10 - Aug 26th, 2014 at 8:16am
It seems to do the opposite in my case... I have a feeling I'm doing something wrong, like not adding something to the list of items passed to the Arrange method.
Thanks for the tip, I'll check it out.
