Normal Topic Understanding the result from ShapeNode.GetIntersection (Read 4459 times)
mihai
Sep 10th, 2014 at 12:49pm
I have a rectangle ShapeNode with the bounds:
left: 30
top: 53
right: 55
bottom: 827.67932489451482
and I need to find out the intersection points with the horizontal line:
BeginPoint	{6.99999999999999; -24.4679324894515}
EndPoint	{282; -24.4679324894515}
However, the result from ShapeNode.GetIntersection is:
{12.5; 387.339662447257}
What am I missing?
-Mihai
Re: Understanding the result from ShapeNode.GetIntersection
Reply #1 - Sep 10th, 2014 at 1:29pm
This method wasn't designed for public use, and its arguments and return value are specified in local coordinates relative to the node's origin. You could use it with diagram's global coordinates like this:
Point relativePoint1 = Node.TransformDiagramToItem(pt1);
Point relativePoint2 = Node.TransformDiagramToItem(pt2);
Point relativeIntersection = Node.GetIntersection(relativePoint1, relativePoint2);
var result =  Node.TransformItemToDiagram(relativeIntersection);
It will return the node's center if the specified line does not intersect it, so you might need an additional check for that.
mihai
Reply #2 - Sep 10th, 2014 at 2:38pm
Hi Stoyan,
Thanks for clarifying!
One last question: how do I find *all* the intersection points of a node with a line? I have tried to divide the hit segment by the intersection point, and call GetIntersection on each segment, but it always seems to return the same intersection point.
Best Regards,
-Mihai
Reply #3 - Sep 10th, 2014 at 3:47pm
Try this method:
List<Point> FindIntersections(DiagramNode node, Point p1, Point p2)
	var bounds = node.Bounds;
	var intersection = new Point();
	var intersections = new List<Point>();
	var corners = new[]
		bounds.TopLeft,
		bounds.TopRight,
		bounds.BottomRight,
		bounds.BottomLeft
	for (int i = 0; i < 4; i++)
		var c1 = corners[i];
		var c2 = corners[(i + 1) % 4];
		if (Utilities.SegmentIntersect(c1, c2, p1, p2, ref intersection))
			intersections.Add(intersection);
	return intersections;
mihai
Reply #4 - Sep 10th, 2014 at 5:15pm
Hi Stoyan,
Cool, that should do it for the rectangle-shaped nodes.
Is there a way to do this more generically, to test for intersections with all the elements that make up a shape node (arc, line and Bezier segments)? Is ShapeNode.GetIntersection taking all these into account?
-Mihai
Reply #5 - Sep 11th, 2014 at 6:07am
This should work for non-rectangular shapes too:
	var geometry = node.GetRegion();
	geometry.Transform = new TranslateTransform(
		bounds.X, bounds.Y);
	var polygon = geometry.GetFlattenedPathGeometry().Figures[0];
	var vertices = new List<Point> { polygon.StartPoint };
	foreach (PolyLineSegment segment in polygon.Segments)
		vertices.AddRange(segment.Points);
	var last = vertices.Count - 1;
	if (vertices[0] == vertices[last])
		vertices.RemoveAt(last);
	for (int i = 0; i < vertices.Count; i++)
		var c1 = vertices[i];
		var c2 = vertices[(i + 1) % vertices.Count];
mihai
Reply #6 - Sep 11th, 2014 at 10:53am
Thanks much Stoyan, it works like a charm!!
-Mihai
