Normal Topic Preventing node overlap (Read 4121 times)
fvkoss
Oct 1st, 2014 at 9:05pm
I've reviewed the documentation in the Placement and Layout section, but I don't see answers for this. I want to create a diagram such that no nodes ever intersect. If the user makes a node larger, I want the nodes that are now partially "covered" to be moved away from the resized node, and if the moved node(s) cover other nodes, them to be moved, etc. I only want the intersecting nodes to move, but not any nodes not directly impacted by the resize. Is there any automatic layout algorithm that will do this (or other API support)? I'm working in C#. Thanks in advance.
Re: Preventing node overlap
Reply #1 - Oct 2nd, 2014 at 8:18am
Try applying SpringLayout with all but the intersected nodes set as Frozen:
private void OnNodeModified(object sender, NodeEventArgs e)
	RemoveOverlaps(e.Node);
void RemoveOverlaps(DiagramNode modifiedNode)
	var overlaps = FindOverlaps(modifiedNode);
	if (overlaps.Count > 0)
		foreach (var node in diagram.Nodes)
			node.LayoutTraits[SpringLayoutTraits.Frozen] = true;
		foreach (var node in overlaps)
			node.LayoutTraits[SpringLayoutTraits.Frozen] = false;
		var springLayout = new SpringLayout();
		springLayout.SplitGraph = false;
		springLayout.Randomize = false;
		springLayout.RepulsionFactor /= 2;
		springLayout.Arrange(diagram);
			node.LayoutTraits.Remove(SpringLayoutTraits.Frozen);
List<DiagramNode> FindOverlaps(DiagramNode modifiedNode)
	var overlaps = new List<DiagramNode>();
		if (modifiedNode == node)
			continue;
		if (modifiedNode.Bounds.IntersectsWith(node.Bounds))
			overlaps.Add(node);
	return overlaps;
fvkoss
Reply #2 - Oct 2nd, 2014 at 2:57pm
Thank you, but it's not quite working.  Nodes move too far.  I've tried playing with the various properties, but the intersected nodes still don't just move the few number of pixels they need to (need link strength and node repulsion to be near 0?).  I wish other layouts had a Frozen trait, because I think that might help another layout to work as desired.
Even if I can't get a built-in layout to work, your pattern for finding overlapping nodes in when a node is modified is very helpful.  Again, thanks.
Reply #3 - Oct 2nd, 2014 at 5:38pm
SpringLayout.NodeDistance specifies desired distance between connected nodes, i.e. it's actually more like a link-length property, so you might add some temporary links if nodes aren't already connected to control the distance.
It's not hard to offset overlapped nodes without using layout classes, e.g. try something along these lines:
	RemoveOverlaps(e.Node, 20);
void RemoveOverlaps(DiagramNode modifiedNode, double minDist)
	var queue = new Queue<DiagramNode>();
	queue.Enqueue(modifiedNode);
	while (queue.Count > 0)
		var node = queue.Dequeue();
		var nodeCenter = node.GetCenter();
		var overlaps = FindOverlaps(node, minDist);
		foreach (var overlap in overlaps)
			var ovrCenter = overlap.GetCenter();
			var ovrBounds = overlap.Bounds;
			var dx = ovrCenter.X - nodeCenter.X;
			var dy = ovrCenter.Y - nodeCenter.Y;
			if (Math.Abs(dx) > Math.Abs(dy))
				// offset horizontally
				if (dx < 0)
					ovrBounds.X = node.Bounds.Left - ovrBounds.Width - minDist;
				else
					ovrBounds.X = node.Bounds.Right + minDist;
			else
				// offset vertically
				if (dy < 0)
					ovrBounds.Y = node.Bounds.Top - ovrBounds.Height - minDist;
				else
					ovrBounds.Y = node.Bounds.Bottom + minDist;
			// shifting the node might introduce new overlaps, continue processing
			overlap.Bounds = ovrBounds;
			queue.Enqueue(overlap);
List<DiagramNode> FindOverlaps(DiagramNode modifiedNode, double minDist)
	var bounds = modifiedNode.Bounds;
	bounds.Inflate(minDist - 1, minDist - 1);
			continue;
		if (bounds.IntersectsWith(node.Bounds))
			overlaps.Add(node);
	return overlaps;
That method also propagates to remaining nodes to make sure shifted overlapped nodes do not introduce new overlaps.
« Last Edit: Oct 3rd, 2014 at 7:26am by Stoyo »
fvkoss
Reply #4 - Oct 6th, 2014 at 7:53pm
I thought of something like that over the weekend, but you beat me to coding.  Thank you again!
