Normal Topic how to set nodes to bottom-layer or to Top-layer? (Read 2612 times)
heyx
Oct 13th, 2014 at 9:34am
hello,
I want to change node's show level in diagram?
Could you tell me is there any method ?
thanks.
Re: how to set nodes to bottom-layer or to Top-layer?
Reply #1 - Oct 13th, 2014 at 9:52am
Try the ZTop and ZBottom methods.
heyx
Reply #2 - Oct 13th, 2014 at 9:59am
Stoyo wrote on Oct 13th, 2014 at 9:52am:
I have tried it, but it don't works.
is any Property of the diagram I don't set?
thanks
Reply #3 - Oct 13th, 2014 at 10:07am
You might not see any change if the nodes are selected at the time you call these methods. Try setting SelectionOnTop = false to allow selected nodes to appear behind other nodes.
heyx
Reply #4 - Oct 14th, 2014 at 1:21am
Stoyo wrote on Oct 13th, 2014 at 10:07am:
thanks for your help, it works now!
