Normal Topic etFontSize causes text to dissappear (Read 3820 times)
Al
Nov 4th, 2014 at 3:23pm
Why does this code cause my node labels to disappear?
Code (Javascript)
            var style = new Style();
            style.setShadowColor(null);
            style.setFontSize(10);
            diagram.setStyle(style);
If I remove the line for 'setFontSize' then all works fine.
Re: etFontSize causes text to dissappear
Reply #1 - Nov 4th, 2014 at 5:01pm
That's size in millimeters if using the default MeasureUnit, and text won't be rendered if there's not enough space available in nodes to fit a single line. If you want to specify font size in points, multiply the value by 25.44 / 72 to get it in millimeters.
Al
Reply #2 - Nov 5th, 2014 at 7:20am
Thanks Stoyan, that worked just fine.
Is there any control over the text style eg. I don't want it to wrap and want to limit it's length?
Reply #3 - Nov 5th, 2014 at 8:32am
The text always wraps at this time. You can work around it like this:
var Text = MindFusion.Drawing.Text;
var originalGetLines = Text.prototype.getLines;
Text.prototype.getLines = function (context)
	var wrappedLines = originalGetLines.apply(this, [context]);
	if (wrappedLines.length < 2)
		return wrappedLines;
	var line = wrappedLines[0];
	line += " ...";
	this.lines = [line];
	return this.lines;
