Hot Topic (More than 10 Replies) Diagram transparency (Read 7756 times)
Al
Nov 5th, 2014 at 9:48am
Is there a way to set the diagram background to transparent? (I mean the whole diagram, not just nodes)
Re: Diagram transparency
Reply #1 - Nov 5th, 2014 at 11:07am
Call diagram.setBackBrush("transparent"); This will show the color of the container div used for scrolling.
Al
Reply #2 - Nov 5th, 2014 at 12:42pm
Thanks Stoyan, that nearly worked -  I think my diagram background is now transparent but now there are some parts of my shape that are not transparent.
The shape I have built should be similar to your built-in IsoProcess shape.
Al
Reply #3 - Nov 5th, 2014 at 12:55pm
Weird, it only seems to be the last node that doesn't get the transparency set (my previous screenshot only had one element ie. it was the first and last)
Reply #4 - Nov 5th, 2014 at 1:39pm
That might be some kind of selection frame, what happens if you call node.setSelected(false) for it? Or try setting Behavior to Modify and moving the last node to see if there's isn't some rectangular node behind it.
Al
Reply #5 - Nov 6th, 2014 at 6:01am
setting node.setSelected(false) has no effect, I don't think the node is selected anyway because I don't see handles.
Using behaviour modify:
1. Clicking the node, it get selected but still has the background.
2. As soon as I move the node it disappears
3. I can't deselect the node after but that may be unrelated.
This is a custom shape node and it happens when I set diagram.setBackBrush("transparent");
Reply #6 - Nov 6th, 2014 at 8:58am
Could you post your Shape definition and node set-up code?
Al
Reply #7 - Nov 6th, 2014 at 9:31am
I am using this routine to build my nodes:
Code (Javascript)
        function CreateShape(bounds, nodeName){
            var arrowShape = new MindFusion.Diagramming.Shape(
                                    {outline: 'M0,100 L90,100 L100,50 L90,0 L0,0 L10,50 L0,100 Z',
            var brush1 =
             type: "LinearGradientBrush",
             color1: "White",
             color2: "#203870",
             angle: 90
            var diagramNode = diagram.getFactory().createShapeNode(bounds);
            diagramNode.setText(nodeName);
            diagramNode.setBrush(brush1);
            diagramNode.setShape(arrowShape);
            var Font = MindFusion.Drawing.Font;
            diagramNode.setFont(new Font("Arial", 8 * 25.44 / 72, false, false));
            return diagramNode;
Reply #8 - Nov 6th, 2014 at 10:36am
This does not show the rectangle for me, could you also post the diagram initialization code in case there's some Diagram property affecting that?
Al
Reply #9 - Nov 6th, 2014 at 2:18pm
No problem, code attached
Code.zip (Attachment deleted)
Reply #10 - Nov 6th, 2014 at 7:36pm
It turns out our developers have only recently added support for transparent background, now I've managed to reproduce this with last released version 2.1. V2.1 doesn't call context.clearRect but only fill("transparent") in your case, which does nothing, so you are seeing the remains of the original rectangular node shape.
This should work fine if you use the beta version here:
http://mindfusion.eu/Forum/YaBB.pl?num=1413273502
We should be releasing v2.2 in a couple of days. If you can't wait, you might also work around that by replacing Canvas.drawBackground with this version:
MindFusion.Drawing.Canvas.drawBackground = function() {
    this.context.clearRect(0, 0, this.bounds.width, this.bounds.height);
The standard function does more things like filling with backBrush and drawing backgroundImage, but that should do if you only need the transparent background.
Al
Reply #11 - Nov 7th, 2014 at 1:18pm
Thanks Stoyan, should this go somewhere special? I put this code in document.ready and it's still the same.
Code (Javascript)
Reply #12 - Nov 7th, 2014 at 5:56pm
Actually replace it in Diagram.prototype:
MindFusion.Diagramming.Diagram.prototype.drawBackground = function ()
Al
Reply #13 - Nov 10th, 2014 at 11:31am
That worked perfectly, thanks Stoyan.
