Very Hot Topic (More than 25 Replies) Email sync to team member's Calendars. (Read 17318 times)
Re: Email sync to team member's Calendars.
Reply #15 - Jun 15th, 2016 at 1:50pm
This is a bug. A fixed version of the assemblies can be downloaded from here:
https://mindfusion.eu/_temp/MindFusion.Scheduling.fix.zip
Let me know if this helps.
TRB
Meppy knows all!!
Reply #16 - Jun 15th, 2016 at 2:30pm
Thanks Meppy, I really appreciate the level of support you provide.
TRB
Reply #17 - Jun 15th, 2016 at 2:42pm
Thank you Wink
TRB
Meppy knows all!!
Reply #18 - Jun 19th, 2016 at 10:56pm
I really apologise for the continual questions, however I now have the following error which is occurring when the export items event is called. "The server is not available. Contact your administrator of this condition persists." I have researched this error and found plenty of information on it but can't find anything that I can do without source code. (I have confirmed the network is connected and outlook is connected to the server). Sorry Meppy.  Undecided
TRB
Reply #19 - Jun 20th, 2016 at 6:38am
Do you get this error every time or did it start appearing at some point? Have you managed to successfully export or import items? Also, do you get a stack trace when this error happen?
TRB
Meppy knows all!!
Reply #20 - Jun 20th, 2016 at 12:09pm
I have been through everything I can and I have something to try tomorrow (getting late here). I found something on the net about a corrupt archive folder causing this issue for someone connecting to outlook. The computer the error is occurring on has multiple archive folders. I will let you know how I go (wish I'd found this before asking you).
TRB
TRB
Meppy knows all!!
Reply #21 - Jun 21st, 2016 at 8:29am
Okay, This worked.  Cheesy  I tried to open each archive until I got to one which gave me the same error message. I removed this archive and the export works 100% correctly. Not sure why this occurs as I wasn't exporting to the archive folder but it must attempt to open it in the background.
TRB
TRB
Meppy knows all!!
Reply #22 - Jun 24th, 2016 at 11:26am
Meppy............ Roll Eyes ...... What are the chances of having the export function save the Mindfusion appointment Id in to the OutlookItem "Mileage" field? Undecided . I feel bad asking but this would make it so much easier to edit and delete outlook events.
TRB
Reply #23 - Jun 27th, 2016 at 6:27am
I'll look into it.
Reply #24 - Jun 27th, 2016 at 7:37am
Try out the version below. It adds a new event to the OutlookExporter class - ItemExported - which lets you transfer additional fields between MindFusion.Scheduling items and their newly created Outlook counterparts during export.
https://mindfusion.eu/_temp/MindFusion.Scheduling2.zip
TRB
Meppy knows all!!
Reply #25 - Jun 27th, 2016 at 11:09am
Thanks so much! This makes it so much easier to match events on import!!  Cheesy
TRB
