Normal Topic how to install mindfusion in win8??? (Read 3301 times)
tests12322
Dec 28th, 2014 at 11:49am
all. i'm trying to install mindfusion Diagramming in win8, but i encount the problem with the error code:1001, and it tell me that there is an error in configration.
"Error 1001. error ocurs when initial setup. System.Configuration.ConfigurationErrorsException: configuration can not initialize"
i have try to install .net framework 2.0 ,which i reference but i can't install it, when i click it ,it happened nothing, and i don't know why.
thanks for helping!!
Re: how to install mindfusion in win8???
Reply #1 - Dec 29th, 2014 at 9:38am
WpfDiagram's installer package lists .NET 3.5 SP1 as a prerequisite, and setup.exe should download and install it if it's not available. I suppose if .NET 2 cannot be installed on your system, .NET 3.5 installer might be failing too. Before running diagram's installer, try enabling .NET 3.5 through Win8 control panel as explained in this MSDN article :
http://msdn.microsoft.com/en-us/library/hh506443(v=vs.110).aspx
Reply #2 - Dec 29th, 2014 at 11:41am
Please check if this setup will work for you, it shouldn't try to install .net 3.5:
https://mindfusion.eu/_beta/WpfDiagTrial.zip
« Last Edit: Dec 29th, 2014 at 12:44pm by Stoyo »
tests12322
Reply #3 - Dec 30th, 2014 at 4:34am
Stoyo wrote on Dec 29th, 2014 at 11:41am:
thank you much for helping me , and your "WpfDiagTrial" is really helpful, and i install it successfully.
but when i want to execute the program, it'll install the .net framework 3.5 (include .net 2.0 and 3.0),
but finally i occur the error 0x80073712. Cry
is there the only way that i have to reinstall my system?
Reply #4 - Dec 30th, 2014 at 9:27am
The pre-compiled examples in that setup still target .NET version 3.5 and Windows will offer you to install it if currently it isn't. Here's a thread discussing that installation error, try the suggestions there before reinstalling the whole OS:
http://answers.microsoft.com/en-us/windows/forum/windows_8-windows_update/how-ca...
I hope that helps.
