Normal Topic Alignment of Diagram (Read 6221 times)
dittu
Feb 25th, 2015 at 11:17am
Is there a way to align the diagram centrally. My diagram, in some specific case has say, 3 nodes, that takes the top left space and whole area is empty (In case of Layered layout), I want this to be centrally aligned with options say Horizontal (0-0-0) or Vertical.
Re: Alignment of Diagram
Reply #1 - Feb 25th, 2015 at 6:59pm
There are no layout centering options available. If you detect the arranged nodes take up less space than the viewport, you could assign new diagram.Bounds coordinates that have the arranged nodes centered in the bounding rectangle:
diagram.arrange(layout);
diagram.resizeToFitItems();
var itemsRect = diagram.getContentBounds();
var viewRect = diagram.getViewport();
if (itemsRect.width < viewRect.width)
	var diagRect = diagram.getBounds();
	diagRect.x = itemsRect.center().x - viewRect.width / 2;
	diagRect.width = viewRect.width;
	diagram.setBounds(diagRect);
If you also want to center when the diagram is larger than current viewport, you could implement it by setting the view's scroll position to the x value found above.
dittu
Reply #2 - Mar 9th, 2015 at 1:51pm
Hi Stoyo,
Thanks for you response. But I was not able to bring my diagram in the centre. Say, as per example
my window/div size is width:900px; height:500px. My canvas size is width="2100" height="2100".
Diagram.getContentBounds() and diagram.getViewport() gives me a very small value compared to these sizes and hardly any difference between those. So, I'm not able to understand what actually viewport is?
I want to display my diagram in the centre of the window, so say, if its 900*500 and if suppose there is only one node it should be centered at 450,250 of window (and I assume canvas as well). So, can you please provide help in this context.
Thanks & Regards
Reply #3 - Mar 10th, 2015 at 11:19am
The code above centers diagram's content (only horizontally) inside the current view. If you want it centered inside the window, you must either make the view's div as big as the window (100% width and height), or set its margins to center it. Attached test page resizes the div to show the node centered in window.
The sizes you get from getViewport and getContentBounds methods are measured in diagram's MeasureUnit, i.e. millimeters by default.
test.zip (Attachment deleted)
dittu
Reply #4 - Mar 22nd, 2015 at 11:25am
Hi Stoyo,
Even if I try to place diagram somewhere in the centre horizontally. Zoom works the initial way, it zooms from top left instead of center. I want zoom centre point to be fixed and zoom in all directions. I found this setZoomFactorPivot (zoomFactor, pivotPoint). Can this help and how?
Thanks a lot.
Reply #5 - Mar 23rd, 2015 at 9:37am
setZoomFactorPivot should help, but now I see it does not work correctly when VirtualScroll is enabled. For time being you could use zoomToRect as a work-around:
function onZoomIn()
	var diagram = $find("diagram");
	var scale = 1.5;
	var vp = diagram.getViewport();
	var c = vp.center();
	if (!diagram.getVirtualScroll())
		diagram.setZoomFactorPivot(diagram.zoomFactor * scale, c);
	else
		vp.x = c.x - (c.x - vp.x) / scale;
		vp.y = c.y - (c.y - vp.y) / scale;
		vp.width /= scale;
		vp.height /= scale;
		diagram.zoomToRect(vp);
« Last Edit: Mar 23rd, 2015 at 12:44pm by Stoyo »
dittu
Reply #6 - Apr 17th, 2015 at 7:03am
Hi Stoyo,
WHt is the exact signature to override this onZoomIn function? I'm using zoomer control.
Reply #7 - Apr 17th, 2015 at 8:08am
The zoom control calls IZoomTarget.setZoomLevel(value) function, you can replace the Diagram implementation like this:
var Diagram = MindFusion.Diagramming.Diagram;
Diagram.prototype.setZoomLevel = function (value)
	var vp = this.getViewport();
	if (!this.getVirtualScroll())
		this.setZoomFactorPivot(value, c);
	else
		var scale = value / this.zoomFactor;
		vp.width /= scale;
		vp.height /= scale;
		this.zoomToRect(vp);
