Normal Topic Outputting diagram as jpeg or svg not working as expected. (Read 4011 times)
AR
Mar 3rd, 2015 at 11:10am
I've been testing the output of my diagrams as images of various types, following the suggestions in the programmers guide.
'gif' and 'png' both work fine - so I will use one of those.
'svg' export outputs everything except my custom composite nodes - these are not present at all. If I wanted to output these to 'svg' format would I need to implement some custom code to do that??
'jpeg' export shows the entire diagram, including custom composite nodes and background image but has an odd 'orange' colour to the image! (see attached file, 'png' output of the same diagram attached for comparison) Any idea what is causing this? How to avoid it if I need 'jpeg' output in the future?
Re: Outputting diagram as jpeg or svg not working as expected.
Reply #1 - Mar 3rd, 2015 at 6:37pm
It seems same problem is described here:
https://github.com/thebuzzmedia/imgscalr/issues/82
createImage returns a BufferedImage in ARGB format, but the Jpeg encoder does not support it. We'll add some createImage parameter to let you specify RGB format for next release.
I suppose our SvgGraphics class does not implement correctly some Graphics2D method called by CompositeNode components. Are you using only Image and Text components in your nodes?
AR
Reply #2 - Mar 4th, 2015 at 9:58am
Yes, they are all I am using.
