Normal Topic MindFusion.WinForms Pack, 2015.R2 (Read 10247 times)
Mar 17th, 2015 at 1:13pm
MindFusion Pack for WinForms 2015.R2 has been released. It adds the following new features:
MindFusion.Diagramming
Visio stencils
MindFusion.Diagramming can now load and display shapes from Visio stencils (.vsx). To load a Visio stencil, use an instance of the VisioStencil class. The shapes are displayed in the diagram through VisioNode objects. To associate a stencil shape with the node, create an instance of the VisioContent class and assign it to the node's Content property.
  • The maximum tab size in TabbedDiagramView can now be specified through the new MaxTabSize property.
  • Type of LinkLabel.Margin property changed from float to Thickness.
  • Initial state of PrintPreviewEx landscape button now corresponds to value of PageSettings.Landscape property.
  • ChangeUnit now also scales child elements of nodes such as TableNode cells and TreeViewNode items.
  • Masters for Start and Arrow7 shapes added to VisioExporter template file.
  • VisioImporter now tries to preserve ShapeNode.Shape when importing from files created by VisioExporter.
  • PolygonalTextLayout now takes into consideration the value StringTrimming.EllipsisCharacter for the Trimming property of the node's TextFormat.
MindFusion.Scheduling
  • Fixed a security exception in MindFusion.Scheduling.WinForms.StandardForms.dll.
The pack is available for download here:
https://www.mindfusion.eu/WinFormsTrial.zip
