Normal Topic Showclocks (Read 3008 times)
Christiaan
Showclocks
May 4th, 2015 at 3:24pm
Hi
Is there an way to change the SHOWCLOCK icon to show the time in text format?
Re: Showclocks
Reply #1 - May 5th, 2015 at 6:30am
You can display the time of the item using custom drawing. To do that, set Calendar.CustomDraw to CustomDrawElements.CalendarItem and handle the Calendar.Draw event. Below you can find a sample implementation
Private Sub Calendar1_Draw(ByVal sender As System.Object, ByVal e As DrawEventArgs) Handles Calendar1.Draw
	Dim time As String = e.Item.StartTime.ToString("H:mm")
	Dim textBrush As New SolidBrush(e.Style.TextColor)
	e.Graphics.DrawString(time, e.Style.Font, textBrush, e.Bounds.X, e.Bounds.Y)
	textBrush.Dispose()
End Sub
