Normal Topic Regarding Link overlap (Read 2109 times)
Pratik
Jun 16th, 2015 at 2:16pm
I Create Workflow diagram programmatically but link between two node not display properly.
link got override behind from node
I try by giveing different anchor point of node also try to update node top bound but it not work
Smiley
Re: Regarding Link overlap
Reply #1 - Jun 17th, 2015 at 7:13am
If you need to avoid overlaps when several links connect same pair of nodes, try the code from LinkCreated handler here, e.g. calling it after you add the last link for the pair:
http://mindfusion.eu/Forum/YaBB.pl?num=1266388133/8#8
If you want to distribute link end points along node borders (not necessarily connecting same opposite node), try running OrthogonalRouter.
