Normal Topic getOrigin/DestinationAnchor after loading a file (Read 2646 times)
billcollis
I love mindfusion
Jul 16th, 2015 at 6:02am
I am getting some strange results with finding anchors.
The functions getOrigin/DestinationAnchor works as expected with a diagram before it is saved. However after reopening the file the results are confusing. The anchor pattern itself does not change, it is always the same
I cannot find any issues with my code so far, but will continue looking.
var ilinks = node.getIncomingLinks();
if (ilinks.length > 0) {
var orig = ilinks[0].getOriginAnchor();
var apt = ilinks[0].getOrigin().getAnchorPattern();
var olinks = node.getOutgoingLinks();
if (olinks.length > 0) {
var dest = olinks[0].getDestinationAnchor();
var apt = olinks[0].getDestination().getAnchorPattern();
billcollis
I love mindfusion
Re: getOrigin/DestinationAnchor after loading a file
Reply #1 - Jul 17th, 2015 at 3:08am
I have reworked the code to stop using getOrigin/DestinationAnchor so much, I only call it once to make the link. It seems to be working fine so far.
Reply #2 - Jul 17th, 2015 at 8:34am
Apparently the anchor point indices aren't serialized at all, and the values you are seeing correspond to where the new link instance would align before loading coordinates from JSON. For time being you can reset index values from loaded link points like this:
diagram.fromJson(...);
var ArrayList = MindFusion.Collections.ArrayList;
ArrayList.forEach(diagram.links, function (link)
	link.originConnection.anchorPointDetails =
			link.originConnection.getNearestAnchor(link.getStartPoint(), link, false);
	link.destinationConnection.anchorPointDetails =
			link.destinationConnection.getNearestAnchor(link.getEndPoint(), link, true);
billcollis
I love mindfusion
Reply #3 - Jul 17th, 2015 at 7:08pm
Thank you so much;
You have a fantastic product and even better service!!!
Bill
