Normal Topic VisibleDateChanged (Read 4156 times)
DavidF
VisibleDateChanged
Jul 22nd, 2015 at 2:10pm
I've spotted what might be a bug with the VisibleDateChanged event. I'm using this to trap when the Month Prev/Next buttons have been selected.
When the event is triggered I am calling 'GetFirstVisibleDate' and GetLastVisibleDate' to get the respective dates. However, it returns the First and Last dates before the VisibleDateChange has happened. How can I get the dates 'after' the Visible Date Change has happened?
E.g. If I'm on July in Month View and click the '>>' button, GetFirstVisibleDate will return 01/07/2015 and GetLastVisibleDate will return 31/08/2015, even though the Visible month is now August and it should return 01/08/2015 and 30/09/2015.
Edit: GetFirstDate and GetLastDate also get the same dates as above. Also not updating after the calendar has changed.
« Last Edit: Jul 22nd, 2015 at 4:07pm by DavidF »
Re: VisibleDateChanged
Reply #1 - Jul 23rd, 2015 at 6:31am
I cannot reproduce this using the most recent build of the component. What is the version of the control you are using in your application? Have you changed the value of any property?
DavidF
Reply #2 - Jul 23rd, 2015 at 8:15am
I am using 4.1.0.20363.
I haven't changed the value of any property.
Update: We have upgraded to version 5.1 and it is now working. Thanks.
« Last Edit: Jul 23rd, 2015 at 9:45am by DavidF »
