Normal Topic Vertically Center-align Content for Shape Node (Read 3037 times)
Santosh
Aug 14th, 2015 at 7:25pm
How to vertically center-align the ShapeNode contents (Image and Text)
I have used the following code:
var sourceNode = diagram.getFactory().createShapeNode(30,30,30,30);
sourceNode.setShape('Circle');
sourceNode.setBrush('#CEF6F5');
sourceNode.setStroke('#30a9c0');
sourceNode.setFont(new Font("Helvetica Neue", 4));
sourceNode.setTextColor('black');
sourceNode.setImageLocation(imgIcons[objType]);
sourceNode.setTextAlignment(Alignment.Center);
sourceNode.setImageAlign(ImageAlign.TopCenter);
Re: Vertically Center-align Content for Shape Node
Reply #1 - Aug 15th, 2015 at 6:09am
You can align text to the bottom by calling node.setLineAlignment(Alignment.Far); You could as well implement custom placement of Text and Image objects:
ShapeNode.prototype.onUpdateVisuals = function ()
	var r = this.getBounds().clone();
	if (this.image)
		r.y += 2; r.height /= 2;
		this.image.setBounds(r);
	this.text.setBounds(
		Rect.fromLTRB(
			r.x,
			this.image ? this.image.bounds.bottom() + 1 : 1,
			r.right(),
			this.getBounds().bottom() - 1));
Santosh
Reply #2 - Aug 17th, 2015 at 6:54am
Thanks Stoyo, that fixed it! Smiley
