Normal Topic Add Spacing between nodes (Read 2233 times)
Santosh
Aug 26th, 2015 at 8:01am
On creating nodes with certain width, the spacing is affected. The nodes tend to overlap each other.
Also, on the cell(0,2) where it shows the progress bar, the width of the cell needs to be equal to the width of the table. Here, specifying colspan is not helping, as the cell's content may overlap the table.
Re: Add Spacing between nodes
Reply #1 - Aug 26th, 2015 at 9:26am
This build should fix TreeLayout:
https://www.mindfusion.eu/_temp/treelayout_js.zip
New version has some classes moved to common.js, which you must load before diagramming.js:
<script src="MindFusion.Common.js" type="text/javascript"></script>
<script src="MindFusion.Diagramming.js" type="text/javascript"></script>
Reply #2 - Aug 26th, 2015 at 9:43am
Setting the progress cell's columnSpan to the number of table columns should fill the entire table now. In older versions the span did count only assigned width of last column; now it should consider its drawn width (as last column auto-fills the table by default).
