Normal Topic Export to PNG/PDF (Read 1540 times)
Andrés
Export to PNG/PDF
Sep 5th, 2015 at 10:57pm
Hello.
Is it possible that, once you have a graph, to export it as PNG or PDF?
Thanks in advance!
Andrés.
Re: Export to PNG/PDF
Reply #1 - Sep 7th, 2015 at 5:05am
You could call the toDataURL method of Canvas element and assign the result to an Img element, which users could then save or print:
http://mindfusion.eu/Forum/YaBB.pl?num=1410270984/1#1
Export to PDF is not supported at this time in standalone JavaScript library; there's a PdfExporter component provided with MindFusion .NET server controls.
