Normal Topic Set focus on a node by code (Read 2534 times)
Santosh
Sep 18th, 2015 at 11:29am
How to select or set focus on a node by code?
Re: Set focus on a node by code
Reply #1 - Sep 18th, 2015 at 12:39pm
You could call node.setSelected(true) to select it.
There's no concept of focused node in the diagram API, but you could change node's colors, run a bouncing animation, or call something like diagram.zoomToRect(node.getBounds().inflate(margin)) to bring the node to user's attention.
Santosh
Reply #2 - Sep 21st, 2015 at 7:28am
thanks Stoyo...the above code zooms the whole diagram...u mentioned adding animation...like the bounce effect...
what could be the code for the bounce effect? or any other animation? is there any animation function for table node?
Reply #3 - Sep 21st, 2015 at 8:01am
Check the Animations example (Animations.js in Samples folder) and this help topic:
http://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm?Animations.htm
Animations should work for TableNodes as well.
