Normal Topic Custom Expand/Collapse buttons (Read 2609 times)
Santosh
Aug 17th, 2015 at 6:53am
How to replace the existing [+] or [-] icon for expand/collapse, with custom icons?
Also, can we place the icon on top-right corner of the node(which should expand/collapse)?
Re: Custom Expand/Collapse buttons
Reply #1 - Aug 17th, 2015 at 9:08am
You can change the button position as shown here:
http://mindfusion.eu/Forum/YaBB.pl?num=1359379520/4#4
Drawing a bitmap image looks like this:
ExpandButton.prototype.updateContent = function ()
	var localRect = this.getRect();
	localRect.x = localRect.y = 0;
	var image = new MindFusion.Drawing.Image(localRect);
	image.image.src = "icon1.png";
	image.loaded = true;
	this.content.push(image);
Srinath
Reply #2 - Aug 12th, 2024 at 5:24pm
Hi Team, When I try to use the above logic in JS Diagramming Library, it throws "ExpandButton is undefined" error.
Am I missing anything here?
Reply #3 - Aug 12th, 2024 at 10:06pm
Unfortunately this class is considered internal and no longer accessible since we moved to es6 classes (the module does not export ExpandButton). For time being you can access the prototype via an instance -
var temp = new ShapeNode(diagram);
temp.expandable = true;
var ExpandButton = temp.expandButton.constructor;
We'll have in mind exporting it for next release.
« Last Edit: Aug 13th, 2024 at 10:36am by Slavcho »
Srinath
Reply #4 - Aug 13th, 2024 at 9:48am
Hi Slavcho,
Thanks for your update. It works !!
Is there a similar logic to change collapse button for shape nodes?
Srinath
Reply #5 - Aug 13th, 2024 at 10:35am
Hi Srinath,
If you mean displaying different icons for expanded and collapsed states, try modifying the code like this -
if (this.node.expanded)
    image.image.src = "collapse.png";
else
    image.image.src = "expand.png";
Reply #6 - Sep 11th, 2024 at 10:41am
Hi Srinath,
This version exports the ExpandButton class as public -
https://mindfusion.eu/_beta/jsdiag45.zip
