Normal Topic Droid trial version (Read 4172 times)
Silvia88
Droid trial version
Sep 4th, 2015 at 7:25pm
sorry but I have a problem, after some time I use the library it writes on the application Droid trial version, how can I solve it?
Re: Droid trial version
Reply #1 - Sep 7th, 2015 at 5:08am
If you have purchased a license, you should have received a license key string. Call the DiagramView.setLicenseKey method with that key as argument to remove the trial label.
Silvia88
Reply #2 - Sep 7th, 2015 at 8:33am
I haven't purchased a license, I would like to know what are the limitations of the trial version and if it expires after some time.
Reply #3 - Sep 7th, 2015 at 10:50am
The trial never expires and doesn't have limitations in functionality other than displaying nag messages.
Silvia88
Reply #4 - Sep 7th, 2015 at 11:34am
Ok, thank you very much  Smiley
