Normal Topic Class HTMLBuilder (Read 3627 times)
superiivan
Class HTMLBuilder
Nov 1st, 2017 at 2:36pm
Hi everyone!
I can't use the method HtmlBuilder.CreateImageHtml because the class HtmlBuilder is not in the library of the DroidDiagram.
I really need to use this, please help me
Re: Class HTMLBuilder
Reply #1 - Nov 2nd, 2017 at 7:17am
We've ported the code for building HTML image map if it's all you need. We'll also have to implement a Diagram.createImage method to have everything from Java version's HtmlBuilder, should be ready in a couple of days.
superiivan
Reply #2 - Nov 2nd, 2017 at 3:37pm
I really need it to make a demo thank you a lot!
Reply #3 - Nov 3rd, 2017 at 7:07pm
This build adds Diagram.createImage method and HtmlBuilder class -
https://mindfusion.eu/_beta/htmlbuilder_android.zip
HtmlBuilder API is same as Java version, with save method taking an extra android.Context parameter - e.g. pass your Activity instance as argument.
