Normal Topic Autowidth Table Cells (Read 2104 times)
Santosh
Sep 9th, 2015 at 10:55am
How can we set the width of cell to be auto-width? So that, the text wraps itself as per the text content on load of diagram?
In the following diagram,
- The text are having spaces to right
- The bars(orange/green) sometimes overlap the table node
Re: Autowidth Table Cells
Reply #1 - Sep 9th, 2015 at 12:08pm
There is no support for cell auto-width. You can find what size will fit the cell's text by calling diagram.measureString, and then set the table width accordingly:
var textSize = diagram.measureString(cell.getText(), table.getEffectiveFont());
var r = table.getBounds();
r.width = textSize.width + 2 /* default text padding */ + imageCellWidth;
table.setBounds(r);
The bars look like something you are custom-drawing, it's up to you to fit them in the table's width (table.getBounds().width).
Santosh
Reply #2 - Sep 10th, 2015 at 5:46am
Thanks Stoyo. Both problems are resolved Smiley
« Last Edit: Sep 10th, 2015 at 7:15am by Santosh »
