Normal Topic Scrollbar Help Needed (Read 1734 times)
rahul
Jul 11th, 2016 at 10:18am
I am using javascript mindfusion created diagram but not able to apply horizontal scrollbar to diagram.Horizontal scrollbar appears to diagram after zoom in but its height is very small hardly visible.
Please help.
Already tried css.
Online
Re: Scrollbar Help Needed
Reply #1 - Jul 11th, 2016 at 10:38am
The scrollbar ranges correspond to the size of diagram.Bounds rectangle. Try setting it to a larger value -
var Rect = new MindFusion.Drawing.Rect;
diagram.setBounds(new Rect(0, 0, 2000, 2000));
If you've already created some diagram elements and cannot scroll to the last of them, you could call diagram.resizeToFitItems() method instead to make the diagram just large enough to contain them all.
